Connecting mySQL and slave mysql monitoring
  • Patryk01
    • Oct 2022
    I'm facing problems while trying to connect my DB into monitoring by my agent zabbix. According to doc. and tutorials after installing zabbix agent there should be a file under location /etc/zabbix/zabbix_agent.d/ with name "userparameter_mysql.conf".
    Unfortunately I'm missing this file on every server because mentioned directory is empty. Does anyone know the solution?
    Main goal is to edit parameters in this file, create new user with privilege's on mysql data base and connect it by creating file "my.cnf" as a credential authentication.
    Later on goal is to monitor second DB and track if they're getting replicated correctly. By also editing "userparemeter_mysql.conf" by adding line:
    "UserParameter=mysql.slavestatus[*],echo “show slave status \G;” | HOME=”Path of credentials” mysql | grep ‘$1’ | awk ‘{print $$2}’ | sed -e ‘s/^NULL$/-1/’"
    Just the point is...i'm missing userparemeter_mysql.conf
    Thank you for all your help
    You need to copy that file there... installing agent does not create any additional mysql userparameters.. its your responsibility to copy that file to each host where you need it.
    • Patryk01
      • Oct 2022
      Sometimes the easiest things are somehow the harderst...
      thank you, is there an official template how does this file need to look somewhere in zabbix.com repository?
        You said you were following somekind of a doc and tutorial... Didn't those mention this?
        There are several different ones on integration page ... https://www.zabbix.com/integration_search?search=mysql One of them uses Userparameters...
