Hello
I have a question regarding SAML and Internal Authentication
We upgrading to the 6.4 and I integrated SecurID SAML auth successfully but I didn't understand how to disable internal authentication for my local user (the same one of SAML)
As described into the doc (3 SAML (zabbix.com)) the user must also exist in Zabbix but the local password is ignored but it's not true
I create a local user "user1" in zabbix with role SuperAdmin and i choose SAML login in frontend. I logged in on SAML IDP as user1 and I was connected as SuperAdmin into Dashboard
If I try to login with internal auth as user1 with local password I also able to logged in...How can I disable this?
Many thanks for your help
