Zabbix: How I upgraded from 6.2.6 to 6.4.1
  • tom.blackstone
    • Sep 2022
    Here is how I upgraded my Zabbix from 6.2.6 to 6.4.1
    Environment:
    Version 6.2.6
    Server: Debian 11
    Componemt: Server, Frontend, Agent
    Database: MySQL
    Web Server: Apache
    These are the steps I took to upgrade. This worked for me:
    1. Take a snapshot of the server in VMware.
    2. PuTTy into server at IP address with ZABBIX credentials
    3. SU root and entered root password
    4. Set PATH for ROOT
      PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
    5. Stop the Zabbix Server
      service zabbix-server stop
    6. Stop the Zabbix Server
      systemctl stop zabbix-server
    7. Remove the old Zabbix Package\files
      dpkg --purge zabbix-release
    8. Download the new Zabbix software
      wget https://repo.zabbix.com/zabbix/6.4/d...bian11_all.deb
    9. Deploy the new Zabbix software
      dpkg -i zabbix-release_6.4-1+debian11_all.deb
    10. Check for updates
      apt-get update
    11. Install Zabbix software
      apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    12. Upgrade the Apached Web Front
      apt-get install zabbix-apache-conf
    13. Next, access the MYSQL database and change rights – notice the semi-colon at the end of each line, which must be included. Run one line at a time
      1. mysql -uroot -p
      2. Enter Root password
      3. mysql> grant all privileges on zabbix.* to zabbix@localhost;
      4. mysql> set global log_bin_trust_function_creators = 1;
      5. mysql> quit;
    14. Reboot the server
      shutdown -r
    Run this command to confirm the database upgrade has been completed
    cat /var/log/zabbix/zabbix_server.log | grep database
    You should see the upgrade, something like this.
    782:20230418:084424.462 completed 0% of database upgrade
    782:20230418:084424.488 completed 1% of database upgrade
    782:20230418:084424.530 completed 2% of database upgrade
    782:20230418:084424.583 completed 3% of database upgrade
    782:20230418:084424.643 completed 4% of database upgrade
    782:20230418:084424.693 completed 5% of database upgrade
    (lines 6% through 95% deleted to shorten this example)
    782:20230418:084438.152 completed 96% of database upgrade
    782:20230418:084438.165 completed 97% of database upgrade
    782:20230418:084438.247 completed 98% of database upgrade
    782:20230418:084438.396 completed 99% of database upgrade
    782:20230418:084438.402 completed 100% of database upgrade
    782:20230418:084438.434 database upgrade fully completed
    595:20230418:084821.642 current database version (mandatory/optional): 06040000/06040000
    1. If the database looks good, access the MYSQL database again and change rights .
      Notice the semi-colon at the end of each line, which must be included.
      Run one line at a time.
      1. mysql -uroot -p
      2. Enter root password
      4. mysql> set global log_bin_trust_function_creators = 0;
      5. mysql> quit;
    On your Web browser, clear your cache and cookies and the access the Zabbix portal​
  • jtnfoley
    • Mar 2022
    • 82
    Cool - Thanks Tom! I'll be doing 6.x to 6.4.x upgrades in four locations very soon!
      Why granting privileges twice in DB? If you had a zabbix instance there already, why do it at all? Shouldn't those privileges be there already ? I can get the point of that global setting (if it is already not set in config), but you should already have rest of it...
      And what's that reboot for? Just to start up server (and flush DB privileges, if its on same server)? Come on... You can do better..
      Depending on your DB size, upgrade can take a while... so you can run "tail -f server.log | grep database" to keep interactive log running
