Zabbix sender: Cannot retrieve key from config cache
  • Martin Law
    • Feb 2021
    • 15
    I'm expieiencing issues with zabbix sender. I've got a zabbix trapper item caller akcp.sender setup and i'm trying to send data to it with zabbix sender.
    How ever i'm getting the following error
    Zabbix Sender output:
    root@geda-zabbix:~# zabbix_sender -vv -z 10.130.198.40 -s "AKCP Zabbix Sender" -k akcp.sender -o "TESTMELDING algemene storing on AKCP Cipal is now 1 , status is now Normal"
    zabbix_sender [2964525]: DEBUG: In zbx_connect_to_server() [10.130.198.40]:10051 [timeout:60, connection timeout:3]
    zabbix_sender [2964525]: DEBUG: In zbx_is_ip4() ip:'10.130.198.40'
    zabbix_sender [2964525]: DEBUG: End of zbx_is_ip4():SUCCEED
    zabbix_sender [2964525]: DEBUG: answer [{"response":"success","info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000051"}]
    Response from "10.130.198.40:10051": "processed: 0; failed: 1; total: 1; seconds spent: 0.000051"
    sent: 1; skipped: 0; total: 1
    Zabbix server log:
    2964159:20230419:150144.198 trapper got '{"request":"sender data","data":[{"host":"AKCP Zabbix Sender","key":"akcp.sender","value":"TESTMELDING algemene storing on AKCP Cipal is now 1 , status is now Normal"}]}'
    2964159:20230419:150144.198 In recv_senderhistory()
    2964159:20230419:150144.198 [B]cannot retrieve key "akcp.sender" on host "AKCP Zabbix Sender" from configuration cache[/B]
    2964159:20230419:150144.198 End of recv_senderhistory()
    The host and item exist, and the config cache reloaded. When that did not work i restarted the server, but that did not help either.
    I could not find anything on the interwebs about this issue, and i'm using zabbix sender on different hosts without errors.
Name:	2023-04-19 15_14_01-GEDA-zabbix_ Configuration of items.png
Name:	2023-04-19 15_24_44-Multi PuTTY Manager.png
    Any help is appreciated, thanks!
    Is that host monitored directly by server or is there any proxy by chance?
