[Helm][Kubernetes] How to add a Pre-Shared Key to zabbix_values.yaml before install
  • nickeshc
    • Apr 2023
    I'm trying to get a Kubernetes cluster Zabbix agent (deployed via Helm) reporting in to a non-Kubernetes Zabbix server via a Zabbix Proxy, but I can't find documentation on how to add a PSK to zabbix_values.yaml on the Zabbix agent before installing it.
    I found this previous post but it didn't seem to work for me - https://www.zabbix.com/forum/zabbix-...psk-encryption
    The error I get looks like this
    kubectl -n monitoring logs pods/zabbix-agent-12345
    2023/04/20 10:48:48.370604 [101] no active checks on server [my.zabbix.proxy:10051]: connection of type "unencrypted" is not allowed for host "my.kubernetes.host"
    2023/04/20 10:49:17.118673 Zabbix Agent 2 stopped. (6.0.16)​
    This is my zabbix_values.yaml file
    cat zabbix/zabbix_values.yaml
    ## nameOverride -- Override name of app
    nameOverride: ""
    ## fullnameOverride -- Override the full qualified app name
    fullnameOverride: ""
    ## kubeStateMetricsEnabled -- If true, deploys the kube-state-metrics deployment
    kubeStateMetricsEnabled: true
    ## Service accoun for Kubernetes API
    rbac:
      ## rbac.create  Specifies whether the RBAC resources should be created
      create: true
      additionalRulesForClusterRole: []
      ##  - apiGroups: [ "" ]
      ##    resources:
      ##      - nodes/proxy
      ##    verbs: [ "get", "list", "watch" ]
    serviceAccount:
      ## serviceAccount.create  Specifies whether a service account should be created
      create: true
      ## serviceAccount.name  The name of the service account to use. If not set name is generated using the fullname template
    ##  **Zabbix proxy** configurations
    zabbixProxy:
      ## Enables use of **Zabbix proxy**
      enabled: false
    ## **Zabbix agent** configurations
    zabbixAgent:
      ## Enables use of Zabbix agent
      enabled: true
      resources: {}
          ##  requests:
          ##   cpu: 100m
          ##   memory: 54Mi
          ##  limits:
          ##   cpu: 100m
          ##   memory: 54Mi
      securityContext: {}
        # fsGroup: 65534
        # runAsGroup: 65534
        # runAsNonRoot: true
        # runAsUser: 65534
      containerSecurityContext: {}
        ## capabilities:
        ##   add:
        ##   - SYS_TIME
      ## Expose the service to the host network
      hostNetwork: true
      # Specify dns configuration options for agent containers e.g ndots
      ## ref: https://kubernetes.io/docs/concepts/services-networking/dns-pod-service/#pod-dns-config
      dnsConfig: {}
      #  options:
      #  - name: ndots
      #    value: "1"
      ## Share the host process ID namespace
      hostPID: true
      ## If true, agent pods mounts host / at /host/root
      hostRootFsMount: true
      extraHostVolumeMounts: []
      ##  - name: <mountName>
      ##    hostPath: <hostPath>
      ##    mountPath: <mountPath>
      ##    readOnly: true|false
      ##    mountPropagation: None|HostToContainer|Bidirectional
      image:
        ## Zabbix agent Docker image name
        repository: zabbix/zabbix-agent2
        ## Tag of Docker image of Zabbix agent
        tag: alpine-6.0.16
        pullPolicy: IfNotPresent
        ## List of dockerconfig secrets names to use when pulling images
        pullSecrets: []
      env:
          ## Zabbix server host
        - name: ZBX_SERVER_HOST
          value: my.zabbix.proxy
          ## Zabbix server port
        - name: ZBX_SERVER_PORT
          value: 10051
          ## This variable is boolean (true or false) and enables or disables feature of passive checks. By default, value is true
        - name: ZBX_PASSIVE_ALLOW
          value: false
          ## The variable is comma separated list of allowed Zabbix server or proxy hosts for connections to Zabbix agent container.
        - name: ZBX_PASSIVESERVERS
          value: 0.0.0.0/0
          ## This variable is boolean (true or false) and enables or disables feature of active checks
        - name: ZBX_ACTIVE_ALLOW
          value: true
          ## The variable is used to specify debug level, from 0 to 5
        - name: ZBX_DEBUGLEVEL
          value: 3
          ## The variable is used to specify timeout for processing checks. By default, value is 4.
        - name: ZBX_TIMEOUT
          value: 4
        ## List can be extended with other environment variables listed here: https://github.com/zabbix/zabbix-docker/tree/6.0/Dockerfiles/agent2/alpine#other-variables
        ## For example:
        ## The variable is comma separated list of allowed Zabbix server or proxy hosts for connections to Zabbix agent container. You may specify port.
        ## - name: ZBX_ACTIVESERVERS
        ##   value: ''
          ## The variable is list of comma separated loadable Zabbix modules. It works with volume /var/lib/zabbix/modules.
        ## - name: ZBX_LOADMODULE
        ##   value: ''
      ## Node selector for Agent. Only supports Linux.
      nodeSelector:
        kubernetes.io/os: linux
      ## Tolerations configurations
      tolerations:
        - effect: NoSchedule
          key: node-role.kubernetes.io/master
      ## Affinity configurations
      affinity: {}
      serviceAccount:
        ## Specifies whether a ServiceAccount should be created
        create: true
        ## The name of the ServiceAccount to use.
        ## If not set and create is true, a name is generated using the fullname template
        annotations: {}
        imagePullSecrets: []
        automountServiceAccountToken: false
      service:
        type: ClusterIP
        port: 10050
        targetPort: 10050
        nodePort: 10050
        portName: zabbix-agent
        listenOnAllInterfaces: true
        annotations:
          agent.zabbix/monitor: "true"
      rbac:
        ## If true, create & use RBAC resources
        create: true
        ## If true, create & use Pod Security Policy resources
        ## https://kubernetes.io/docs/concepts/policy/pod-security-policy/
        ## PodSecurityPolicies disabled by default because they are deprecated in Kubernetes 1.21 and will be removed in Kubernetes 1.25.
        ## If you are using PodSecurityPolicies you can enable the previous behaviour by setting `rbac.pspEnabled: true`
        pspEnabled: false
        pspAnnotations: {}​
    As per the forum post, I applied the following configmap after installing the Zabbix agent
    cat zabbix/zabbix_psk.yaml
    kind: ConfigMap
    apiVersion: v1
    metadata:
    namespace: monitoring
    labels:
        app=zabbix
        controller-revision-hash=5748f4568b
        name=zabbix-agent
        pod-template-generation=1
    data:
    zabbix-agent-psk-key:  ​<my_key>
    I'm happy to provide any additional information,
    Thanks in advance!
