Webhook GLPI - ERROR_SESSION_TOKEN_MISSING
  • keat
    • Apr 2023
    OS : Debian 11 Bullseye
    Zabbix : v6.2
    GLPI : v10
    i'm trying to setup GLPI webhook to create a new "problem" based on the default "GLPi" media type.
    When I test it, i got a error from GPLI API (see screenshot).
    What I understand :
    • Webhook authenticate correctly using the API token that i provided
    • Then, webhook send a request to GLPI server with an empty 'Session-Token'
    It seems Zabbix can connect to GLPI because I receive a response.
    I thought the problem was on GLPI side so i checked and cURL.
    When i send a request, I get a SSL certificate error. It's because GLPI certificate is signed using my own root CA.
    I tried passing the root CA using --cacert cURL option and it works. Same using --insecure option.
    I added my root CA in /usr/share/ca-certificates and did a 'sudo apt update-ca-certificates'. Nothing
    I added my root CA in /etc/ssl/certs/. Same
    I don't know if the issue is the root CA because it seems GLPI server respond to webhook's requests.
    Nothing in the logs on both side.
    Anyone knows which service is executing webhooks ?
    Which path is Zabbix reading root CA files from ?
    Thanks​
  • Answer selected by keat at 10-05-2023, 18:08.
    keat
    • Apr 2023
    I couldn't figure how to use the default webhook so I wrote mine from scratch using the following documentation :
    Zabbix JS Preprocessing : https://www.zabbix.com/documentation...ing/javascript
    Objects, methods supported by JS Duktape : https://www.zabbix.com/documentation...script_objects​
    My script only allow me to create a new ticket on alert trigger. It is crappy but I share it in case it can help someone.
    // Script Engine : Duktape
    // Parse value from Zabbix params
    params = JSON.parse(value),
    AUTH_TOKEN = params.auth_token
    GLPI_URL = params.glpi_url
    TITLE = params.alert_subject
    MESSAGE = params.alert_message
    URGENCY = params.event_nseverity
    function getAuthToken(url, auth_token) {
    auth_header = 'Authorization: user_token ' + auth_token
    // Embbed cURL
    request = new HttpRequest()
    request.addHeader('Content-Type: application/json');
    request.addHeader(auth_header);
    response = request.get(url + 'apirest.php/initSession/');
    response = JSON.parse(response)
    // Return only data from key "session_token"
    return response.session_token
    // Create a ticket
    try {
    SESSION_TOKEN = getAuthToken(GLPI_URL, AUTH_TOKEN)
    // Request body
    ticket_data = {
    'input': {
    'name': TITLE,
    'requesttypes_id': 7, // Modify the "demand source"
    'status': 1, // Set status "New"
    'content': MESSAGE,
    'entities_id': 0, // Set to root entity
    'urgency': URGENCY
    glpi_ticket_url = GLPI_URL + "apirest.php/Ticket/"
    request.addHeader('Session-Token: ' + SESSION_TOKEN);
    // Send POST request.
    // Data has to be converted from Object to JSON using JSON.stringify().
    response = request.post(glpi_ticket_url, JSON.stringify(ticket_data));
    Zabbix.log(4, '[ GLPI Webhook ] Result: ' + JSON.stringify(response));
    return JSON.stringify(response);
    catch (error) {
    Zabbix.log(4, '[ GLPI Webhook ] ERROR: ' + error);
    throw 'Sending failed: ' + error + ' data :' + JSON.stringify(ticket_data);
    The media type I created :
    Message template is the default "Problem" one ​.​
    • Telmo Marques
      • Apr 2023
      • 17
      I am with the same problem! Before yesterday everything was okay and today the zabbix can't connect to glpi...and i don't know why
      • Telmo Marques
        • Apr 2023
        • 17
        i already fix the problem! Removing Application token (App_Token) from client of API in GLPi will fix the error.
        • Lauro Italo
          Lauro Italo commented
          @telmo you removed the Removing Application token from the media type script ? post the fix please
      • keat
        • Apr 2023
        // Embbed cURL
        // Create a ticket
        try {
        // Request body
        ticket_data = {
        'input': {
        'name': TITLE,
        'content': MESSAGE,
        'urgency': URGENCY
        catch (error) {
        • frmoronari
          • Nov 2023
          Zabbix : v6.2
          GLPI : v10
          Click image for larger version  Name:	image.png Views:	306 Size:	11.7 KB ID:	463346​
          What I understand :
          Thanks​
          I have a same error,
          do you grant solution for this case?​
          • soumya
            • Nov 2013
            • 21
            HI keat,
            all you need to do, is to delete the app_token, got generated for the apiclient, in GLPI & save. This will solve your problem.Click image for larger version
            • renatobeiriz
              • Nov 2023
              • 20
              keat
              when i use ur code, and test, have this error
              • leonardon
                leonardon commented
                I have the same problem, did you manage to solve it?
