Zabbix 3.0 installation in centos 7
  • Balaraju
    • Jun 2016
    • 40
    Hi team
    Can any one help how to install the zabbix 3.0 in cento 7.
    I have installed zabbix3.0 in centos 7. But i am not able to start the zabbix-server . i am getting below error.
    error: Job for zabbix-server.service failed because a fatal signal was delivered to the control process. See "systemctl status zabbix-server.service" and "journalctl -xe" for details.
    I have disabled selinux in config.But still i am getting error.
  • aib
    • Jan 2014
    • 1615
    Did you check log-files for zabbix-server (/var/log/zabbix/zabbix_server.log) and MySQL (/var/log/mysql*)
    Did you find any error messages? Did you fix it?
    Sincerely yours,
    Aleksey
    • Balaraju
      • Jun 2016
      • 40
      zabbix 3.0 installation in centos 7
      HI team,
      i am find below log /var/log/zabbx/zabbix_server.log
      2722:20160608:000624.466 7f2faaa89000-7f2faac89000 ---p 00028000 fd:00 134502031 /usr/lib64/libssh2.so.1.0.1
      2722:20160608:000624.466 7f2faac89000-7f2faac8a000 r--p 00028000 fd:00 134502031 /usr/lib64/libssh2.so.1.0.1
      2722:20160608:000624.466 7f2faac8a000-7f2faac8b000 rw-p 00029000 fd:00 134502031 /usr/lib64/libssh2.so.1.0.1
      2722:20160608:000624.466 7f2faac8b000-7f2faad53000 r-xp 00000000 fd:00 134608873 /usr/lib64/libnetsnmp.so.31.0.2
      2722:20160608:000624.466 7f2faad53000-7f2faaf52000 ---p 000c8000 fd:00 134608873 /usr/lib64/libnetsnmp.so.31.0.2
      2722:20160608:000624.466 7f2faaf52000-7f2faaf55000 r--p 000c7000 fd:00 134608873 /usr/lib64/libnetsnmp.so.31.0.2
      2722:20160608:000624.466 7f2faaf55000-7f2faaf57000 rw-p 000ca000 fd:00 134608873 /usr/lib64/libnetsnmp.so.31.0.2
      2722:20160608:000624.466 7f2faaf57000-7f2faaf8d000 rw-p 00000000 00:00 0
      2722:20160608:000624.466 7f2faaf8d000-7f2faafed000 r-xp 00000000 fd:00 134608886 /usr/lib64/libodbc.so.2.0.0
      2722:20160608:000624.466 7f2faafed000-7f2fab1ec000 ---p 00060000 fd:00 134608886 /usr/lib64/libodbc.so.2.0.0
      2722:20160608:000624.466 7f2fab1ec000-7f2fab1ed000 r--p 0005f000 fd:00 134608886 /usr/lib64/libodbc.so.2.0.0
      2722:20160608:000624.466 7f2fab1ed000-7f2fab1f4000 rw-p 00060000 fd:00 134608886 /usr/lib64/libodbc.so.2.0.0
      2722:20160608:000624.466 7f2fab1f4000-7f2fab1f5000 rw-p 00000000 00:00 0
      2722:20160608:000624.467 7f2fab1f5000-7f2fab353000 r-xp 00000000 fd:00 134398329 /usr/lib64/libxml2.so.2.9.1
      2722:20160608:000624.467 7f2fab353000-7f2fab552000 ---p 0015e000 fd:00 134398329 /usr/lib64/libxml2.so.2.9.1
      2722:20160608:000624.467 7f2fab552000-7f2fab55a000 r--p 0015d000 fd:00 134398329 /usr/lib64/libxml2.so.2.9.1
      2722:20160608:000624.467 7f2fab55a000-7f2fab55c000 rw-p 00165000 fd:00 134398329 /usr/lib64/libxml2.so.2.9.1
      2722:20160608:000624.467 7f2fab55c000-7f2fab55e000 rw-p 00000000 00:00 0
      2722:20160608:000624.467 7f2fab55e000-7f2fab56b000 r-xp 00000000 fd:00 134608837 /usr/lib64/libiksemel.so.3.1.1
      2722:20160608:000624.467 7f2fab56b000-7f2fab76a000 ---p 0000d000 fd:00 134608837 /usr/lib64/libiksemel.so.3.1.1
      2722:20160608:000624.467 7f2fab76a000-7f2fab76b000 r--p 0000c000 fd:00 134608837 /usr/lib64/libiksemel.so.3.1.1
      2722:20160608:000624.467 7f2fab76b000-7f2fab76c000 rw-p 0000d000 fd:00 134608837 /usr/lib64/libiksemel.so.3.1.1
      2722:20160608:000624.467 7f2fab76c000-7f2faba4a000 r-xp 00000000 fd:00 201606763 /usr/lib64/mysql/libmysqlclient.so.18.0.0
      2722:20160608:000624.467 7f2faba4a000-7f2fabc49000 ---p 002de000 fd:00 201606763 /usr/lib64/mysql/libmysqlclient.so.18.0.0
      2722:20160608:000624.467 7f2fabc49000-7f2fabc51000 r--p 002dd000 fd:00 201606763 /usr/lib64/mysql/libmysqlclient.so.18.0.0
      2722:20160608:000624.467 7f2fabc51000-7f2fabc66000 rw-p 002e5000 fd:00 201606763 /usr/lib64/mysql/libmysqlclient.so.18.0.0
      2722:20160608:000624.467 7f2fabc66000-7f2fabc6b000 rw-p 00000000 00:00 0
      2722:20160608:000624.467 7f2fabc6b000-7f2fabc8c000 r-xp 00000000 fd:00 134339112 /usr/lib64/ld-2.17.so
      2722:20160608:000624.467 7f2fabd34000-7f2fabe68000 rw-s 00000000 00:04 196614 /SYSV7300f7c3 (deleted)
      2722:20160608:000624.468 7f2fabe68000-7f2fabe84000 rw-p 00000000 00:00 0
      2722:20160608:000624.468 7f2fabe88000-7f2fabe8a000 rw-s 00000000 00:04 229383 /SYSV5300f7c3 (deleted)
      2722:20160608:000624.468 7f2fabe8a000-7f2fabe8b000 rw-p 00000000 00:00 0
      2722:20160608:000624.468 7f2fabe8b000-7f2fabe8c000 rw-p 00000000 00:00 0
      2722:20160608:000624.468 7f2fabe8c000-7f2fabe8d000 r--p 00021000 fd:00 134339112 /usr/lib64/ld-2.17.so
      2722:20160608:000624.468 7f2fabe8d000-7f2fabe8e000 rw-p 00022000 fd:00 134339112 /usr/lib64/ld-2.17.so
      2722:20160608:000624.468 7f2fabe8e000-7f2fabe8f000 rw-p 00000000 00:00 0
      2722:20160608:000624.468 7fffcfd25000-7fffcfd46000 rw-p 00000000 00:00 0 [stack]
      2722:20160608:000624.468 7fffcfdfe000-7fffcfe00000 r-xp 00000000 00:00 0 [vdso]
      2722:20160608:000624.468 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
      2722:20160608:000624.468 ================================
      2722:20160608:000624.468 Please consider attaching a disassembly listing to your bug report.
      2722:20160608:000624.468 This listing can be produced with, e.g., objdump -DSswx .
      • Balaraju
        • Jun 2016
        • 40
        Hi team,
        I am using centos 7 minimal ,
        for mariadb log
        160608 00:04:52 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
        160608 0:04:52 [Note] /usr/libexec/mysqld (mysqld 5.5.47-MariaDB) starting as process 1803 ...
        160608 0:04:53 InnoDB: The InnoDB memory heap is disabled
        160608 0:04:53 InnoDB: Mutexes and rw_locks use GCC atomic builtins
        160608 0:04:53 InnoDB: Compressed tables use zlib 1.2.7
        160608 0:04:53 InnoDB: Using Linux native AIO
        160608 0:04:53 InnoDB: Initializing buffer pool, size = 128.0M
        160608 0:04:53 InnoDB: Completed initialization of buffer pool
        160608 0:04:53 InnoDB: highest supported file format is Barracuda.
        160608 0:04:54 InnoDB: Waiting for the background threads to start
        160608 0:04:55 Percona XtraDB (http://www.percona.com) 5.5.46-MariaDB-37.6 started; log sequence number 6171674
        160608 0:04:55 [Note] Plugin 'FEEDBACK' is disabled.
        160608 0:04:55 [Note] Server socket created on IP: '0.0.0.0'.
        160608 0:04:55 [Note] Event Scheduler: Loaded 0 events
        160608 0:04:55 [Note] /usr/libexec/mysqld: ready for connections.
        Version: '5.5.47-MariaDB' socket: '/var/lib/mysql/mysql.sock' port: 3306 MariaDB Server
        • Balaraju
          • Jun 2016
          • 40
          when i am checking the status the below is displayed
          [root@localhost ~]# systemctl status zabbix-server.service
          zabbix-server.service – Zabbix Server
          Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; disabled)
          Active: activating (auto-restart) (Result: signal) since Wed 2016-06-08 02:05:56 EDT; 2s ago
          Process: 2642 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=killed, signal=SEGV)
          Jun 08 02:05:56 localhost.localdomain systemd[1]: zabbix-server.service: control process exited, code=killed status=11
          Jun 08 02:05:56 localhost.localdomain systemd[1]: Failed to start Zabbix Server.
          Jun 08 02:05:56 localhost.localdomain systemd[1]: Unit zabbix-server.service entered failed state.
          • mkdr27
            • Oct 2016
            • 9
            Zabbix 3.2 installation in centos 7
            I'm also facing the same issue.
            Is there any solution for this error?
            • MightBeAWizard
              • May 2016
              • 33
              SELinux is on by default, check your /var/log/audit/audit.log since SELinux might be the reason why you can't start Zabbix
