Having issues with LDAP authentication
  • bisana
    • Jul 2005
    • 87
    Dear All,
    Good afternoon
    I am trying to authenitcate Zabbix with LDAP, we have done the necessary configuration with the authentication setup , but when we try to test LDAP login, it is throwing error
    Like to request, any menthod in which I can get more info of what is happening [ such as log files, or any particular files to check ]
    I am pasting here the LDAP test error which we are getting
    Request guidance or pointers
    thanks
    Joseph John
  • bisana
    • Jul 2005
    • 87
    Like to update, the issues is solved
    Only lately I realoized that you need to create users in Zabbix and then configure it for Active directory.
    We did and now I checked for Zabbix 6 as well as Zabbix 7 alpha, both the we configured for active directory authentication
    thanks
    Joseph John
      That's a failure to read docs, I would say... Its literally on the first line of text (ldap for 6.0)...
      LDAP authentication
      External LDAP authentication can be used to check user names and passwords. Note that a user must exist in Zabbix as well, however its Zabbix password will not be used.
