6.4 fstab (nfs) mounts.
  • Tristis Oris
    • Sep 2015
    • 66
    After last changes to mountpoints, is it any way to get native auto discovery for fstab, nfs\cifs paths? Without agent or OS modifications and custom scripts.
    Added monitoring of mount point options for Unix-like OSes
    vfs.fs.get and vfs.fs.discovery, used for discovery of mounted filesystems, now additionally return filesystem mount options in the "options" and "{#FSOPTIONS}" property respectively. These options allow to detect filesystems that remounted as read-only (e.g. on VMs) or to filter bind mounts or .dmg volumes on macOS.
  • Tristis Oris
    • Sep 2015
    • 66
    yes, got it.
    not that at macro tabs.
    {$VFS.FS.FSTYPE.MATCHES} just need to add
    |nfs|nfs3|nfs4|cifs|smb
    • Tristis Oris
      • Sep 2015
      • 66
      Next step to check is folder mounted or not.
        If your discovery finds them, then they are mounted... both vfs.fs.get and vfs.fs.discovery return data about "mounted filesystems"...
        • Tristis Oris
          • Sep 2015
          • 66
          not sure how to to make it.
          need something like
          find(/hostname/vfs.fs.get[{#FSNAME}],1,"like","failed")=0
          but got
          Incorrect item key "vfs.fs.get[{#FSNAME}]"
          or that work only for trigger prototypes?
          well, trigger doesn't matter right now. After any first umount, history for this item stop working.
          from latest data:
          Preprocessing failed for: [{"fsname":"/sys","fstype":"sysfs","bytes":{"total":0,"free":0,"used":0,"pfree":0,"pused":0},"ino...
          1. Failed: cannot extract value from json by path "$.[?(@.fsname=='/mnt/kopia-backup/')].first()": no data matches the specified path
          so with prototype
          find(/kopia/vfs.fs.dependent[{#FSNAME},data],1,"like","Failed")=1
          host trigger
           Cannot evaluate function find(/kopia/vfs.fs.dependent[/mnt/kopia-backup/,data],1,"like","Failed"): item is not supported.​
          after umount.
