How to export a screen for use in report doc?
  • Heinrich
    • Mar 2023
    • 18
    Dear community,
    working with zabbix 5.0 I was wondering how export an host screen to use it as a report in another document.
    For example, if I have a client with a server and at the end of the month, I want to present him his serverdata in a report (word doc, saved as a pdf).
    It would be great to use a dashboard export, because it is easy to setup, but as far as I know, it is not intendet to do so.
    So next would be screens. But how could I export a screen? Doesn´t work neither.
    Any hint is wellcome.
    Thanks in advance
    Heinrich
    Screens are dead end. Your 5.0 still has them, newer ones do not.
    upgrade to (at least) 6.0, use web services to generate reports? https://www.zabbix.com/documentation...config/reports
    • Heinrich
      • Mar 2023
      • 18
      Thanks a lot for the link. I will read this and guess you are right regarding the update.
      Have a nice weekend​
