How to config zabbix in docker container to monitor vmware
  • Tec_francis
    • Apr 2023
    Hi guys!!
    I am trying zabbix 6.4 in Docker container and I would like monitor vmware but I do not know how edit "/etc/zabbix/zabbix_server.conf" and restart service.
  • Mrbibi
    • May 2024
    Hey,
    You need to configure this through the environment variables. Each zabbix_server.conf parameters can be configured this way
    From https://www.zabbix.com/documentation...ion/containers:
    All Zabbix component images provide environment variables to control configuration. These environment variables are listed in each component repository. These environment variables are options from Zabbix configuration files, but with different naming method. For example, ZBX_LOGSLOWQUERIES is equal to LogSlowQueries from Zabbix server and Zabbix proxy configuration files.
    In your case the following paramters of zabbix_server.conf
    StartVMwareCollectors=3
    VMwareFrequency=60
    VMwarePerfFrequency=60
    VMwareCacheSize=32M
    VMwareTimeout=120
    Have to be passed as environment variables like bellow (docker-compose):
    # VMware monitoring settings
    ZBX_STARTVMWARECOLLECTORS: 3
    ZBX_VMWAREFREQUENCY: 60
    ZBX_VMWAREPERFFREQUENCY: 60
    ZBX_VMWARECACHESIZE: 32M
    ZBX_VMWARETIMEOUT: 120
    Have a nice day.
    • einsteinagogo
      einsteinagogo commented
      is this still valid in 2025 ?
  • Mrbibi
    • May 2024
    einsteinagogo, yes, I think so. Check the documentation to see if anything has changed, or perform a simple test. Then, inspect the zabbix_server.conf inside the container to verify if the changes have been applied correctly.
    • einsteinagogo
      • Feb 2025
      Does not parse these variables into the container
      • Brambo
        • Jul 2023
        • 250
        See my post in this topic: https://www.zabbix.com/forum/zabbix-...055#post500055
