Hi All,
I am running Zabbix and monitoring most of my host using active checks. I see only disk space usage are shown for root partition ("/") and all other disks mounted to hosts are not displayed for those hosts which are monitored using "zabbix Active Agent". However for passive check I see all disk are coming on zabbix panel.
Is there something I am missing? I have used default template for both then why there is difference. For active check I am not getting mounted disk details but for passive check I am getting details for other mounted disk.
Please guide me to enable the monitoring for mounted filesystem over Zabbix Active check.
