Trigger Trouble
  • thefuzz4
    • Feb 2015
    • 16
    Trigger Trouble
    So I have this trigger that I created
    {Template App Splunk Forwarder Serviceroc.num[,root,all,splunkd].last(0)}=0
    All I want it to do is if there are 0 splunkd processes running let the trigger fire so the action can be ran to go restart the forwarder.
    Problem is that in my logs with debug level 5 turned on this is what I see
    38974:20160610:093458.274 In evaluate_function() function:'havok01roc.num[,root,all,splunkd].last(0)'
    So I can see its trying to evaluate it. Zabbix does indeed tell me that the forwarder is down. I just don't think that my trigger is written correctly in order to catch this state.
    I think that once I have this thing working correctly the action should fire. If not I'll visit that next. I've read through the wiki and searched to no end to try and find a nice example of what I'm attempting to pull off here. Thank you all for your help with this in advance and I'm sure its something simple and stupid.
  • LenR
    • Sep 2009
    • 1011
    Does latest data for the item show the number of running procs and does it go to 0 when none are running?
    • thefuzz4
      • Feb 2015
      • 16
      Good Evening Len,
      Yes in the graph it will show that the number went from 2 to 0 and the dashboard does show that the process is not running.
      • thefuzz4
        • Feb 2015
        • 16
        So when I'm intentionally attempting to trigger this thing
        I have the debug level set at 5 and I see this in the logs
        100548:20160613:160431.452 In evaluate_function() function:'havok01:proc.num[,root,all,splunkd].last(0)'
        1. Splunk Forwarder Process (havok01:proc.num[,root,all,splunkd]): 0
        100549:20160613:160501.026 In evaluate_function() function:'havok01:proc.num[,root,all,splunkd].last(0)'
        Which does tell me that hey the trigger sees it but for whatever reason the action will not fire.
        This is what the action is looking for
        Maintenance status not in maintenance
        Template = Template App Splunk Forwarder Service
        Trigger value = PROBLEM
        Trigger severity >= Warning
        • LenR
          • Sep 2009
          • 1011
          I've never used the Template condition before, you might remove that for testing.
          Can you post what you have for the operation?
          Also for testing, change your operation to just send an email. Make sure the user in the email has permissions for the host. (Our most frequent problem with actions is permissions)
          • thefuzz4
            • Feb 2015
            • 16
            Ok so here is the trigger conditions
            Here is the action
            Send message to user groups: Zabbix administrators via all media
            I know that it should be sending an email out now
            Looking at the actions result on the dashboard just shows my default notification. It still didn't fire though .
            Thank you so much for your help with this. I'm sure there is something silly that I'm just overlooking here with this.
            • LenR
              • Sep 2009
              • 1011
              More basic questions, sorry if they are obvious things you've already done.
              1) Other action emails work?
              2) The trigger appears on the dashboard with Warning or higher severity?
              • thefuzz4
                • Feb 2015
                • 16
                Yeah the default message email works that came with the install.
                No nothing shows up on the dashboard for this action/trigger that anything happened.
                • LenR
                  • Sep 2009
                  • 1011
                  That sounds like the problem is in the trigger then.
                  Maybe try just proc.num[splunkd] for the item.
                  • thefuzz4
                    • Feb 2015
                    • 16
                    So something like this?
                    Service:proc.num[splunkd].last(0)}=0
                    • LenR
                      • Sep 2009
                      • 1011
                      Yes, I actually have that trigger, save for the template name. I have one case where it triggered, but it's several months ago. It probably triggered at reboot, it was 0 for 1 sample cycle, so it wouldn't have tripped any operation in my action.
                      • thefuzz4
                        • Feb 2015
                        • 16
                        Can you share your expression. I'm trying to save it but I keep getting
                        Incorrect trigger expression. Check expression part starting from "Service:proc.num[splunkd].last(0)=0".
                        • LenR
                          • Sep 2009
                          • 1011
                          Here's the template - https://file.io/qezl0j
                          Did you change the item first? Simplify the item key, the trigger should change automatically.
                          • thefuzz4
                            • Feb 2015
                            • 16
                            Woohoo that did the trick by changing the item key. Thank you so much for your help with this mess
                            • LenR
                              • Sep 2009
                              • 1011
                              #15
                              I still don't understand why the original item proc.num[,root,all,splunkd] didn't work. That should have been "all" processes, running as root, in any state, with splunkd in the command line.
                              I can test on my splunkd running host with zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf -t proc.num[,root,all,splunkd] and I get 4. With proc.num[splunkd], I get 3. I suspect the 4 includes the zabbix_agentd running with the parm :-)
