Events table column
  • user1234
    • Jul 2022
    • 35
    Events table column
    hi,
    is it possible to play with events columns?
    i mean for example to move tags column to be the after problem column as follow?
  • Answer selected by user1234 at 02-05-2023, 23:27.
    Hamardaban
    • May 2019
    • 2714
    The interface is written in PHP.
    If you have the knowledge , then you can change it (CScreenProblem.php)
    • user1234
      user1234 commented
      Thanks you so much!
      it's really worked!!
  • max_bz
    • Mar 2023
    • 17
    As far as I know, the interface in Zabbix is hardcoded. So most likely you can change it only by building your own version from sources )
    • Hamardaban
      • May 2019
      • 2714
      • user1234
        user1234 commented
        Thanks you so much!
