Zabbix Widget help
  • user1234
    • Jul 2022
    • 35
    Zabbix Widget help
    Hi
    i'm trying to create widget in Zabbix as follow:
    But when I'm clicking on the host group name in order to see the problems with the specific tags - it gives me all problem without any filter.
    does any one know if it's a bug in zabbix?​
  • max_bz
    • Mar 2023
    • 17
    Hey
    Make sure everything is correct with the host groups.
    I just checked with myself and everything is working fine.
    The widget shows groups and the number of hosts in them with/without problems.
    When I click on a group, it takes me to that particular group's problems page.​
    • user1234
      • Jul 2022
      • 35
      everything looks correct.
      which zabbix version do you have?
      • max_bz
        • Mar 2023
        • 17
        zabbix_server (Zabbix) 6.0.14
