Need help monitor application keep crashing
  • sohozabbix
    • Jun 2016
    Hi, I'm a newbie to Zabbix. Pls be gentle
    One of our custom applications is crashing randomly. Not everyday. How can I configure Zabbix to monitor this application which is installed on a terminal server. Thanks.
  • StarDestroyer
    • Jun 2014
    • 20
    I have an .exe that I monitor with the following Key (Type is Zabbix Agent):
    proc_info[EventMgr.exe,wkset,sum]
    Then I set up a trigger to tell me when it's not running ( .last()=0 )
    • LenR
      • Sep 2009
      • 1010
      A more generic answer, you need to create a way for Zabbix to monitor the status of that application. The prior post was for a .exe where you have the zabbix agent installed. Another way would be watching for a listening port (agent test) or use a simple test to watch a TCP service port, which wouldn't even need the agent (but might need firewall changes)
      Get it monitored, then build a trigger with logic to identify a bad state, then create an action to notify or correct the bad state.
