Ceph Error
  • thinkplus++
    • May 2023
    Ceph Error
    I created an item for ceph and name as Ceph Status in zabbix web gui with additional information below:
    Type: zabbiz agent
    Key: ceph.status
    Type of Information: Character
    Added also the user parameter in zabbix agent configuration:
    UserParameter=ceph.status, ceph --format json status
    And I getting the Last value message:
    Error initializing cluster client: ObjectNotFOund('Rados object not found ( error calling conf_read_file)')
    Action taken:
    • Check the cluster running properly
    • Check the ceph configuration
    • Check the ceph heath status
    • check the ownership permission.
    Can someone please share how it can be fix.
    Thank you
