Assigning Interface to JMX items
  • AnjinMeili
    • Jun 2016
    I have been working with trying to assign an interface to an Item via Templates. Would anyone have examples? When I use the <interface_ref> in a Host entry, it fails to assign properly. I have tried to build an index first using <interfaces><interface>, then referencing the <interface_ref> in the <item> without success. Imports will work fine, but the default interface is the one always selected. I have been beating my head on this for awhile and figured it might be best to just ask and see. I have found that I can import a template, then do a mass update to properly select the port. But would prefer to import a template and have the port assigned at import. Apologize if this is a redundant query, I have poked about and find that the above mentioned manual step seems commonly quoted.
  • AnjinMeili
    • Jun 2016
    More information. I thought I might assign values to the interface_ref based on the port, after all, it should just be a charval. But, on import, the following stanza:
    <interface>
    <default>0</default>
    <type>4</type>
    <useip>1</useip>
    <ip>10.2.17.77</ip>
    <dns>mygh-dca-qa02.ghc.org</dns>
    <port>11555</port>
    <interface_ref>if11</interface_ref>
    </interface>
    Becomes:
    <interface>
    <type>4</type>
    <useip>1</useip>
    <ip>10.2.17.77</ip>
    <port>11555</port>
    <interface_ref>if3</interface_ref>
    </interface>
    This clearly shows that the interface_ref is assembled at save, and not parsed from the XML.
