Does pg_dump Zabbix DB in PostgreSQL with TimescaleDB need adding '-Fc' option
  • wyang
    • Mar 2016
    • 93
    I am a beginner of PostgreSQL and TimescaleDB. As per TimescaleDoc https://docs.timescale.com/self-host...ntire-database, the command to backup a database named tsdb​ is
    pg_dump -Fc -f tsdb.bak tsdb​
    which uses '-Fc' option (output file format custom).
    I was wondering if this option is needed for zabbix db backup? or output file format plain text (default) is good? Thanks very much!
