monitor file access - ransomware detection
  • xanadu
    • Sep 2014
    • 62
    In the hunt in detecting cryptolocker alike malware I'm looking for a way to detect abnormal file access behaviour.
    I already placed one dummy.docx file where I check modification access and it's checksum, but this is only within one directory and hasn't proved to be effective as we had a cryptolocker inside another directory.
    Is there a way where we can enable zabbix to monitor abnormal file access / changes which are in automated way?
    All ideas are welcome!
  • xanadu
    • Sep 2014
    • 62
    Is there anything we could do with running sysinternals process explorer and using it virustotal.com functionality?
    • ServicedeskITS
      • Jun 2016
      I think using Zabbix for this is not ideal.
      Coz when it happens you are too late.
      Best thing as far as i know is to use File System Resource Manager on Windows Server
      This will prevent files from being changed to a different extension and hopefully also for the file from being infected as well.
      • Wasur
        • Mar 2017
        Thank you! Very helpful
        http://manual-removal.com/crypt0l0cker-2017/
