Zabbix dashboard on signage display
  • damage
    • Apr 2022
    I would like to use a Zabbix dashboard in a signage software (more specific in anthias). As the signage software just displays websites or local media it is only possible to do http basic authentication (hopefully by injecting into the url, but haven't tested yet).
    Any idea on how to get a dashboard get displayed on a signage display without manually entering the credentials?
    I thought setting user authentication to "http" in Zabbix web but that would effect all other users, too. Would it be possible to run a seconds Zabbix web instance using the same Zabbix server as the first web instance? Thus one could active HTTP-authentication?
    regards
    Daniel
