snmp via zabbix client agent
  • pkinoo
    • May 2023
    I would like to monitor a remote 4G internet router using snmp.
    We have a VPN connection with a device which is behind that router, on which a zabbix client agent is installed.
    Does the Zabbix agent have a builtin command to read snmp ?
    Or do we need to install & use an external command like snmpget ?
    (fyi we do not want to enable snmp on the WAN interface of that router, and it is not a fixed WAN IP anyway)
    Nope... Agent needs additional commands, what you use through userparameters.
    Usual SNMP polling is done by proxy/server, not by agent.
