trigger snmptrap[regex] catching
  • Spirou
    • Jun 2016
    • 62
    i must use regular expression and try to catch 2 things in a trigger with snmptrap[<regex>].
    The line i am getting with snmptrap is :
    15:44:16 2016/06/02 .1.3.6.1.4.1.2.6.158.3.0.4 Normal "Status Events" Y012UN19F0EG 4 8 Recovery
    I need to catch .1.3.6.1.4.1.2.6.158.3.0.4 Recovery and fire the trigger
    any ideas pls, ty
    regards
  • Spirou
    • Jun 2016
    • 62
    UP !
    i try this :
    snmptrap[".1.3.6.1.4.1.2.6.158.3.0.4|removed"]
    snmptrap[".1.3.6.1.4.1.2.6.158.3.0.4|Recovery"]
    but it seem not work, because the line i send contain only "removed" and it take the other one (Recovery)...
    any idea pls
    regards.
    • Spirou
      • Jun 2016
      • 62
      Hi, all
      can you confirm me pls its possible to do multireg with snmptrap item zabbix ?
      like this :
      snmptrap[{".1.3.6.1.4.1.2.6.158.3.0.22"} && {"trap4"}]
      i need to catch ".1.3.6.1.4.1.2.6.158.3.0.22" && "trap4"
      2 are required.
      ty
      regards.
      • macman
        • Aug 2016
        Hello Spirou,
        I am sorry but I can't answer your question, instead I have a question for you. I am facing the problem that I am using the key snmptrap too and I in my latest data there shows nothing.
        I was curious if you have data in latest data.
        Kind regards
        macman
