Low-Level Discovery Rule(s) with dependent item
  • RoBeDi
    • Mar 2022
    I am hoping to get some extra brains in this project. I am trying to monitor the Dell PowerVault ME4024 with a JSON file, using LLD with a dependent item. At the moment, Dell does not provide or has a working MIB to use SNMP to monitor this device with Zabbix.
    I have created an Python script to generate a JSON file, with the selected API basetype properties. An extract of the Python script is shown below.
    !/usr/bin/env python3
    commands = (
       "controllers",
      # "controller-statistics",
      # "disks",
      # "fans",
      # "frus",
      # "pools",
      # "ports",
      # "power-supplies",
      # "sensor-status",
       "system",
      # "volumes",
      # "volume-statistics",
    def main(argv=None):
        data_list = {"data":[],"lld":[
            {"{#CNTLRS}": "controllers"}
        for element in commands:
            r = s.get(url + "/api/show/" + element)
            parsed = json.loads(r.content)
            data_list["data"].append(parsed)
        print(json.dumps(data_list, indent=4))
    if __name__ == "__main__":
        sys.exit(main())
    After successfully creating the JSON file, which contains several JSON arrays. Each JSON array contains several JSON Objects. An example JSON file is shown below.
        "data": [
                "controllers": [
                        "object-name": "controllers",
                        "meta": "/meta/controllers",
                        "durable-id": "controller_a",
                        "controller-id": "A",
                        "controller-id-numeric": 1,
                        "serial-number": "xxx",
                        "hardware-version": "9.1",
                        "cpld-version": "3.9",
                        "mac-address": "xxx",
                        "node-wwn": "xxx",
                        "ip-address": "xxx",
                        "ip-subnet-mask": "255.255.254.0",
                        "ip-gateway": "xxx",
                        "ip6-link-local-address": "xxx",
                        "ip6-link-local-gateway": "::",
                        "ip6-auto-address": "::/0",
                        "ip6-auto-address-source": "DHCPv6",
                        "ip6-auto-address-source-numeric": 0,
                        "ip6-auto-gateway": "",
                        "ip61-address": "::/0",
                        "ip61-gateway": "::",
                        "ip62-address": "::/0",
                        "ip62-gateway": "::",
                        "ip63-address": "::/0",
                        "ip63-gateway": "::",
                        "ip64-address": "::/0",
                        "ip64-gateway": "::",
                        "disks": 12,
                        "number-of-storage-pools": 0,
                        "virtual-disks": 1,
                        "cache-memory-size": 4096,
                        "system-memory-size": 8192,
                        "host-ports": 4,
                        "drive-channels": 2,
                        "drive-bus-type": "SAS",
                        "drive-bus-type-numeric": 8,
                        "status": "Operational",
                        "status-numeric": 0,
                        "failed-over": "No",
                        "failed-over-numeric": 0,
                        "fail-over-reason": "Not applicable",
                        "fail-over-reason-numeric": 0,
                        "sc-fw": "GTS280R10-29",
                        "vendor": "DELL EMC",
                        "model": "ME4024",
                        "platform-type": "Gallium3 LX",
                        "platform-type-numeric": 6,
                        "multicore": "Enabled",
                        "multicore-numeric": 1,
                        "sc-cpu-type": "Broadwell",
                        "sc-cpu-speed": 2200,
                        "internal-serial-number": "00C0FF658C19",
                        "cache-lock": "Yes",
                        "cache-lock-numeric": 1,
                        "write-policy": "write-back",
                        "write-policy-numeric": 0,
                        "description": "ASSY,ENCL,CTL,SAS,ME40XXS,12G",
                        "part-number": "FXGPW",
                        "revision": "A01",
                        "dash-level": "",
                        "fru-shortname": "",
                        "mfg-date": "2021-12-17 23:16:00",
                        "mfg-date-numeric": 1639782960,
                        "mfg-location": "",
                        "mfg-vendor-id": "",
                        "locator-led": "Off",
                        "locator-led-numeric": 0,
                        "ssd-alt-path-io-count": 3,
                        "health": "OK",
                        "health-numeric": 0,
                        "health-reason": "",
                        "health-recommendation": "",
                        "position": "Top",
                        "position-numeric": 2,
                        "rotation": "0 Degrees",
                        "rotation-numeric": 0,
                        "phy-isolation": "Enabled",
                        "phy-isolation-numeric": 0,
                        "redundancy-mode": "Active-Active ULP",
                        "redundancy-mode-numeric": 8,
                        "redundancy-status": "Redundant",
                        "redundancy-status-numeric": 2,
                        "network-parameters": [
                                "object-name": "controller-a",
                                "meta": "/meta/network-parameters",
                                "durable-id": "mgmtport_a",
                                "active-version": 4,
                                "gateway": "xxx",
                                "subnet-mask": "255.255.254.0",
                                "addressing-mode": "DHCP",
                                "addressing-mode-numeric": 2,
                                "link-speed": "1000mbps",
                                "link-speed-numeric": 2,
                                "duplex-mode": "full",
                                "duplex-mode-numeric": 0,
                                "auto-negotiation": "Enabled",
                                "auto-negotiation-numeric": 1,
                                "health": "OK",
                                "ping-broadcast": "Enabled",
                                "ping-broadcast-numeric": 1
                        "port": [
                                "object-name": "ports",
                                "meta": "/meta/port",
                                "durable-id": "hostport_A0",
                                "controller": "A",
                                "controller-numeric": 1,
                                "port": "A0",
                                "port-type": "SAS",
                                "port-type-numeric": 8,
                                "media": "SAS",
                                "target-id": "500c0fff24ef4000",
                                "status": "Up",
                                "actual-speed": "12Gb",
                                "actual-speed-numeric": 11,
                                "configured-speed": "",
                                "configured-speed-numeric": 255,
                                "fan-out": 1,
                                "health": "OK",
                                "sas-port": [
                                        "object-name": "port-details",
                                        "meta": "/meta/sas-port",
                                        "configured-topology": "Direct",
                                        "configured-topology-numeric": 0,
                                        "width": 4,
                                        "sas-lanes-expected": 4,
                                        "sas-active-lanes": 4,
                                        "sas-disabled-lanes": 0
                                "durable-id": "hostport_A1",
                                "controller": "A",
                                "port": "A1",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4100",
                                "status": "Up",
                                "fan-out": 1,
                                "health": "OK",
                                "sas-port": [
                                        "width": 4,
                                "durable-id": "hostport_A2",
                                "controller": "A",
                                "port": "A2",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4200",
                                "status": "Disconnected",
                                "status-numeric": 6,
                                "actual-speed": "Auto",
                                "actual-speed-numeric": 3,
                                "fan-out": 1,
                                "health": "N/A",
                                "health-numeric": 4,
                                "health-reason": "There is no active connection to this host port.",
                                "health-recommendation": "- If this host port is intentionally unused, no action is required.  - Otherwise, use an appropriate interface cable to connect this host port to a switch or host.  - If a cable is connected, check the cable and the switch or host for problems.",
                                "sas-port": [
                                        "width": 4,
                                        "sas-active-lanes": 0,
                                "durable-id": "hostport_A3",
                                "controller": "A",
                                "port": "A3",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4300",
                                "fan-out": 1,
                                "health": "N/A",
                                "sas-port": [
                                        "width": 4,
                        "expander-ports": [
                                "object-name": "expander-port",
                                "meta": "/meta/expander-ports",
                                "durable-id": "expport_universal_0.A0",
                                "enclosure-id": 0,
                                "controller": "A",
                                "sas-port-type": "Expansion Port Universal",
                                "sas-port-type-numeric": 5,
                                "sas-port-index": 0,
                                "name": "Expansion Port",
                                "health": "N/A",
                                "health-reason": "No drive enclosure is connected to this expansion port. This is normal if this is the last (or only) enclosure in the cabling sequence of the system.",
                                "health-recommendation": "- No action is required."
                        "compact-flash": [
                                "object-name": "controller-a-compact-flash",
                                "meta": "/meta/compact-flash",
                                "durable-id": "Ctlr A CF",
                                "name": "Controller A CompactFlash",
                                "status": "Installed",
                                "status-numeric": 1,
                                "cache-flush": "Enabled",
                                "cache-flush-numeric": 1,
                                "health": "OK",
                        "expanders": [
                                "object-name": "expanders",
                                "meta": "/meta/expanders",
                                "durable-id": "expander_0.A",
                                "enclosure-id": 0,
                                "drawer-id": 255,
                                "dom-id": 0,
                                "path-id": "A",
                                "path-id-numeric": 1,
                                "name": "Root Expander-A",
                                "location": "Enclosure 0, Iom A",
                                "status": "OK",
                                "extended-status": "00000000",
                                "fw-revision": "52B2",
                                "health": "OK",
                        "durable-id": "controller_b",
                        "controller-id": "B",
                        "controller-id-numeric": 0,
                        "node-wwn": "500C0FFF24EF4000",
                        "disks": 12,
                        "virtual-disks": 1,
                        "host-ports": 4,
                        "model": "ME4024",
                        "internal-serial-number": "00C0FF658B84",
                        "revision": "A01",
                        "dash-level": "",
                        "mfg-location": "",
                        "health": "OK",
                        "position": "Bottom",
                        "position-numeric": 3,
                        "rotation": "180 Degrees",
                        "rotation-numeric": 2,
                                "object-name": "controller-b",
                                "durable-id": "mgmtport_b",
                                "gateway": "xxx",
                                "health": "OK",
                        "port": [
                                "durable-id": "hostport_B0",
                                "controller": "B",
                                "controller-numeric": 0,
                                "port": "B0",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4400",
                                "status": "Up",
                                "fan-out": 1,
                                "health": "OK",
                                "sas-port": [
                                        "width": 4,
                                "durable-id": "hostport_B1",
                                "controller": "B",
                                "port": "B1",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4500",
                                "status": "Up",
                                "fan-out": 1,
                                "health": "OK",
                                "sas-port": [
                                        "width": 4,
                                "durable-id": "hostport_B2",
                                "controller": "B",
                                "port": "B2",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4600",
                                "fan-out": 1,
                                "health": "N/A",
                                "sas-port": [
                                        "width": 4,
                                "durable-id": "hostport_B3",
                                "controller": "B",
                                "port": "B3",
                                "port-type": "SAS",
                                "media": "SAS",
                                "target-id": "500c0fff24ef4700",
                                "fan-out": 1,
                                "health": "N/A",
                                "sas-port": [
                                        "width": 4,
                        "expander-ports": [
                                "durable-id": "expport_universal_0.B0",
                                "enclosure-id": 0,
                                "controller": "B",
                                "health": "N/A",
                        "compact-flash": [
                                "object-name": "controller-b-compact-flash",
                                "durable-id": "Ctlr B CF",
                                "name": "Controller B CompactFlash",
                                "health": "OK",
                        "expanders": [
                                "durable-id": "expander_0.B",
                                "enclosure-id": 0,
                                "drawer-id": 255,
                                "dom-id": 0,
                                "path-id": "B",
                                "path-id-numeric": 0,
                                "name": "Root Expander-B",
                                "location": "Enclosure 0, Iom B",
                                "status": "OK",
                                "health": "OK",
                "status": [
                        "object-name": "status",
                        "meta": "/meta/status",
                        "response-type": "Success",
                        "response-type-numeric": 0,
                        "response": "Command completed successfully. (2023-05-15 10:28:40)",
                        "return-code": 0,
                        "component-id": "",
                        "time-stamp": "2023-05-15 10:28:40",
                        "time-stamp-numeric": 1684146520
                "system": [
                        "object-name": "system-information",
                        "meta": "/meta/system",
                        "system-name": "PVME",
                        "system-contact": "John Doe",
                        "system-location": "SOR",
                        "system-information": "Dell EMC PowerVault ME4024",
                        "midplane-serial-number": "xxx",
                        "vendor-name": "DELL EMC",
                        "product-id": "ME4024",
                        "product-brand": "",
                        "scsi-vendor-id": "DellEMC",
                        "scsi-product-id": "ME4",
                        "enclosure-count": 1,
                        "health": "OK",
                        "other-MC-status": "Operational",
                        "other-MC-status-numeric": 4760,
                        "pfuStatus": "Idle",
                        "supported-locales": "English (English), Spanish (espa\u00f1ol), French (fran\u00e7ais), German (Deutsch), Japanese (\u65e5\u672c\u8a9e), Korean (\ud55c\uad6d\uc5b4), Chinese-Simplified (\u7b80\u4f53\u4e2d\u6587)",
                        "current-node-wwn": "N/A",
                        "fde-security-status": "Unsecured",
                        "fde-security-status-numeric": 1,
                        "platform-type": "Gallium",
                        "platform-type-numeric": 3,
                        "platform-brand": "DELL EMC",
                        "platform-brand-numeric": 22,
                        "redundancy": [
                                "object-name": "system-redundancy",
                                "meta": "/meta/redundancy",
                                "controller-a-status": "Operational",
                                "controller-a-status-numeric": 0,
                                "controller-a-serial-number": "xxx",
                                "controller-b-status": "Operational",
                                "controller-b-status-numeric": 0,
                                "controller-b-serial-number": "xxx",
                "status": [
                        "response": "Command completed successfully. (2023-05-15 10:28:41)",
                        "return-code": 0,
                        "component-id": "",
                        "time-stamp": "2023-05-15 10:28:41",
                        "time-stamp-numeric": 1684146521
        "lld": [
    At this moment, I am able to create items (JSON array: system) configured with an Master Item. But I failed to created a Discovery Rule for the JSON array: controllers. I have researched different options and methods, but all failed. Currently, I got one Discovery Rule configured:
    Links consulted:
    - https://blog.zabbix.com/low-level-di...t-items/13634/
    - https://www.zabbix.com/forum/zabbix-...m-prototype​
    How can I make this happen? Only one working configuration is needed, to be an example for others.
