Mirror read-only view to zabbix-Dashboard to on-premise system
  • siegmarb
    • Nov 2014
    • 25
    Hi folks,
    we are happy zabbix users and monitor several independent customers with our central zabbix system. However, one customer asks now for read access to his "hosts/services". Basically this would be simply a user and appropriate permissions, but i do not like the idea of exposing our internal system and have a customer with read access. Especially that granting a wrong permission in our system could possibly lead to an unwanted privilege escalation.
    I was thinking about another zabbix-server on-premise that talks also to the agents/clients, but that requires configuration in 2 places.
    How do you guys solve this?
    Thank you.
    Stefan.
  • NgRox
    • Jun 2022
    • 45
    Boa tarde, se você der acesso aos hosts e serviços, ele terá acesso informações de outros clientes? Se sim, cria um Zabbix separado e nos agents dos hosts desse determinado cliente, seta no parametro Server e ServerActive os endereços ip's ou dns de ambos os servidores Zabbix.
    Me corrija se compreendi corretamente ou não!
    Atenciosamente
      Building separate instance is overkill. If it is ok for you to have at least a user for them (under your control) set up a grafana instance with zabbix plugin. User for integration will have limited access to only those hostgroups you configure ie, their data..
