Problem with Discovery rule --> Filters
  • TheBonaZabbix
    • Feb 2023
    • 67
    Dear all,
    I have a problem with filters in a discovery rule.
    Surely I'm wrong but I don't understand what.
    I don't understand why some interfaces are automatically filtered while others are not.
    These are the Template’s filters
    These are the Template’s macro
    If I test the Discovery rule on a device I obtain
    {"{#SNMPINDEX}":"1","{#IFOPERSTATUS}":"2","{#IF ADM INSTATUS}":"2","{#IFALIAS}":"","{#IFNAME}":"AT0"," {#IFDESCR}":"ATM0","{#IFTYPE}":"94"},
    {"{#SNMPINDEX}":"2","{#IFOPERSTATUS}":"1","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Et0"," {#IFDESCR}":"Ethernet0","{#IFTYPE}":"6"},
    {"{#SNMPINDEX}":"3","{#IFOPERSTATUS}":"1","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"Interfaccia Switched","{#IFNAME}":"Fa0","{#IFDESCR}":"FastEthe rnet0","{#IFTYPE}":"6"},
    {"{#SNMPINDEX}":"4","{#IFOPERSTATUS}":"1","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"Interfaccia Switched","{#IFNAME}":"Fa1","{#IFDESCR}":"FastEthe rnet1","{#IFTYPE}":"6"},
    {"{#SNMPINDEX}":"5","{#IFOPERSTATUS}":"2","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Fa2"," {#IFDESCR}":"FastEthernet2","{#IFTYPE}":"6"},
    {"{#SNMPINDEX}":"6","{#IFOPERSTATUS}":"2","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Fa3"," {#IFDESCR}":"FastEthernet3","{#IFTYPE}":"6"},
    {"{#SNMPINDEX}":"7","{#IFOPERSTATUS}":"1","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Vo0"," {#IFDESCR}":"VoIP-Null0","{#IFTYPE}":"1"},
    {"{#SNMPINDEX}":"8","{#IFOPERSTATUS}":"1","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Nu0"," {#IFDESCR}":"Null0","{#IFTYPE}":"1"},
    {"{#SNMPINDEX}":"9","{#IFOPERSTATUS}":"7","{#IF ADM INSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"ATM0-atm layer","{#IFDESCR}":"ATM0-atm layer","{#IFTYPE}":"37"},
    {"{#SNMPINDEX}":"10","{#IFOPERSTATUS}":"7","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"ATM0. 0-atm subif","{#IFDESCR}":"ATM0.0-atm subif","{#IFTYPE}":"134"},
    {"{#SNMPINDEX}":"11","{#IFOPERSTATUS}":"7","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"ATM0-aal5 layer","{#IFDESCR}":"ATM0-aal5 layer","{#IFTYPE}":"49"},
    {"{#SNMPINDEX}":"12","{#IFOPERSTATUS}":"7","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"ATM0. 0-aal5 layer","{#IFDESCR}":"ATM0.0-aal5 layer","{#IFTYPE}":"49"},
    {"{#SNMPINDEX}":"13","{#IFOPERSTATUS}":"2","{#I FAD MINSTATUS}":"2","{#IFALIAS}":"","{#IFNAME}":"AT0-adsl","{#IFDESCR}":"ATM0-adsl","{#IFTYPE}":"94"},
    {"{#SNMPINDEX}":"18","{#IFOPERSTATUS}":"2","{#I FAD MINSTATUS}":"2","{#IFALIAS}":"","{#IFNAME}":"NV0", "{#IFDESCR}":"NVI0","{#IFTYPE}":"1"}],
    {"{#SNMPINDEX}":"14","{#IFOPERSTATUS}":"1","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Et0-vdsl2","{#IFDESCR}":"Ethernet0-vdsl2","{#IFTYPE}":"251"},
    {"{#SNMPINDEX}":"15","{#IFOPERSTATUS}":"2","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Vl1", "{#IFDESCR}":"Vlan1","{#IFTYPE}":"53"},
    {"{#SNMPINDEX}":"16","{#IFOPERSTATUS}":"1","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"","{#IFNAME}":"Et0.9 0","{#IFDESCR}":"Ethernet0.90","{#IFTYPE}":"135 "},
    {"{#SNMPINDEX}":"17","{#IFOPERSTATUS}":"1","{#I FAD MINSTATUS}":"1","{#IFALIAS}":"Interfaccia LAN","{#IFNAME}":"Vl2","{#IFDESCR}":"Vlan2","{#IF T YPE}":"53"}
    I have highlighted 2 detected interfaces (AT0-adsl and NV0)
    Coming to the question (finally)....
    Why is the NV0 interface present in the device’s interfaces while the AT0-adsl interface is not present?
    Could anyone give me a suggestion?
    What am I missing?
    Thank you
    Good day
    AT0-adsl interface is not present​ because of following.
    {"{#SNMPINDEX}":"13","{#IFOPERSTATUS}":"2","{#IFADMINSTATUS}":"2","{#IFALIAS}":"","{#IFNAME}":"AT0-adsl","{#IFDESCR}":"ATM0-adsl","{#IFTYPE}":"94"}
    Maybe that NV0 was not with that admin status at the moment of discovery? Is it maybe marked as "not discovered any more" ?
    • TheBonaZabbix
      • Feb 2023
      • 67
      I'm afraid I messed up the configuration.
      Previously, a template with unfiltered discovery was probably applied to the hosts.
      It had detected all interfaces.
      Now I've made some peace with my brain and the new tests are giving me the desired results.
      Interfaces are properly filtered.
      Thank you so much Cyber for your precious help.
      Have a Good day​!
