Cpu
  • tapto
    • Nov 2006
    • 28
    Cpu
    how do i monitor more than one cpu ?
    I have tried
    system.cpu.load[1,avg1]
    is that the correct syntax ?
    on my system it goes to not suported
  • jeff.showers
    • Aug 2006
    • 18
    I've run into that one as well. Most I was able to pull was the aggregate (combined) cpu utilization by using the key 'system.cpu.load[,avg1]'. Also be aware if this is a windows system that a number of keys don't work with the stock win32 agent that you can download from www.zabbix.com.
    • tapto
      • Nov 2006
      • 28
      I'm running on Linux with agent 1.1.3
      No sure if i use the correct syntax for montoring cpu ???
      • mary nancy
        • Jul 2005
        • 125
        hi,
        I am using zabbix 1.1.1 , I am not finding a suitable parameter to monitor CPU utilization on a windows machine. I browsed www.zabbix.com/documentation.
        Any parameter that i configure as per the document it is showing as "NOT SUPPORTED"
        Can somebody let me know what is the appropriate parameter
        Thanks and regards
        Nancy
