Zabbix Proxy passive mode not working
  • capaciticci
    • May 2016
    i configured my zabbix proxy for passive mode and it isn't collecting data or sending it to the server. i configured a host in the UI for Item=Zabbix agent and type Zabbix proxy and we get no latest data. i see in the server log file that it is sending data to Zabbix proxy which is my hostname of my zabbix proxy but thats all i see, there is still no latest data. not sure what i'm missing here.
    zabbix_proxy.conf:
    ProxyMode=1
    Hostname=Zabbix proxy
    LogFile=/var/log/zabbix-proxy/zabbix_proxy.log
    DebugLevel=3
    DBName=zabbix
    DBUser=zabbix
    DBPassword=*******
    ConfigFrequency=120
    everything else is default
  • kloczek
    • Jun 2006
    • 1771
    First: Item=Zabbix agent it is for how proxy is communicating with agents so this has nothing to do with passive proxy settings.
    Second: if in proxy cfg file there is no Server= entry pointing to zbx server proxy will be not able ask server for hosts monitoring configuration.
    • capaciticci
      • May 2016
      proxy passve
      according to the cfg file, when proxy is in passive mode the Server= field is ignored
      • kloczek
        • Jun 2006
        • 1771
        I'm sorry .. you are right this time.
        However as I wrote proxy settings have nothing to do with used types of zabbix agent metrics
        • capaciticci
          • May 2016
          zabbix proxy passive
          so then what am i missing that i get no latest data?
          • kloczek
            • Jun 2006
            • 1771
            Do you see in proxy log that proxy is receiving cfg data from server?
            As long as you are using passive items do you see in proxy pooler log connecting to the agents to collect metrics data? Do you see in agents logs connections from the proxy?
            PS. BTW passive monitoring does not scale well so you should be IMO more focused on use active items.
            • capaciticci
              • May 2016
              i see in my server log that it send data to proxy, then proxy starts doing stuff.
              i see in the proxy log that it tried pinging the host then it stops there and doesnt send data to the server
