Does Zabbix support monitoring on MongoDB servers
  • Akansha123
    • Jun 2016
    • 54
    Does Zabbix support monitoring on MongoDB servers? Or is it only supported on MySQL and PostGRE servers?
  • bbrendon
    • Sep 2005
    • 873
    Yes. It supporting monitoring of anything. Heartrate, moon locations, coke machines, CPU.
    You name it, it can monitor it.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • zalums
      • May 2016
      Hi Akansha123,
      If I understood you correctly and you want to install Zabbix using MongoDB then it`s not supported.
      You can check documentation to see what DB`s are supported.
      • Akansha123
        • Jun 2016
        • 54
        Hi Zalums,
        Thanks for the reply!
        I have been searching all over to configure MongoDB with Zabbix.
        Actually I was wondering why MongoDB cannot be used as Zabbix back-end database? Is it because since the schema created through MongoDB cannot be used by Zabbix?Or is there any other specific reason?
        I am not sure if it is making much sense
