Zabbix don't server doesn't start
  • nicolasfo
    • Jul 2015
    • 56
    Hello everyone,
    Yesterday, I've done a Debian update, like I do once a month, if necessary.
    After the reboot, Zabbix server doesn't start with the following error message :
    May 17 14:41:05 zabbix systemd[1]: Stopped Zabbix Server.
    May 17 14:41:05 zabbix systemd[1]: Starting Zabbix Server...
    May 17 14:41:05 zabbix zabbix_server[896]: /usr/sbin/zabbix_server: symbol lookup error: /usr/sbin/zabbix_server: undefined symbol: usmHMAC192SHA256AuthProtocol
    May 17 14:41:05 zabbix systemd[1]: zabbix-server.service: Control process exited, code=exited, status=127/n/a
    May 17 14:41:05 zabbix systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 17 14:41:05 zabbix systemd[1]: Failed to start Zabbix Server.
    Nothing in /var/log/zabbix/zabbix_server.log
    After a little search, I decided to restore a Veeam backup of the VM, wich I know the server started, same error.
    I seems the error is not related to the Debian update, so I really don't know where to search.
    Debian 11 and Zabbix 6.4.1 installed.
    Do you have a clue ?
    Nicolas
  • Hamardaban
    • May 2019
    • 2714
    Take a look at this : https://www.zabbix.com/forum/zabbix-...92privprotocol
    • nicolasfo
      • Jul 2015
      • 56
      Thanks for your reply.
      I already checked on the forum and found this thread, but nothing works.
      I saw the problem could be about SNMP, I had run those commands :
      apt --reinstall install libsnmp*
      apt --reinstall install snmp
      Without success
      I also change "localhost" by the internal IP of the server and reboot the server in /usr/share/zabbix/conf/zabbix.conf.php, same result, same error message.
      Thanks !
