Zabbix Discovery rule Powershell command not working
  • CristianR
    • Apr 2023
    • 12
    Hello Zabbix Community,
    I am trying to create a LLD Discovery rule in Zabbix that extract the folder name and the parent folder name. It works perfectly if I run the PowerShell command in Powershell but when I test it on Zabbix I get
    Invalid second parameter.​
    error.
    Here's the code:
    system.run[powershell.exe -NoProfile -ExecutionPolicy bypass -c "Get-ChildItem -Path c:\apps -Directory -filter tomcat-* | Get-ChildItem -Directory | select name, @{Name = 'ParentFolder'; Expression = {$_.Parent.Name}}|ConvertTo-Json"]
    Any Idea how to overcome this problem?
    Thank you.
  • Answer selected by CristianR at 18-05-2023, 08:53.
    Hamardaban
    • May 2019
    • 2713
    I think that the problem is with quotes in the expression. system.run takes part of your expression as its second parameter....
    try something like
    system.run["powershell.exe -NoProfile -ExecutionPolicy bypass -c 'Get-ChildItem -Path c:\apps -Directory -filter tomcat-* | Get-ChildItem -Directory | select name, @{Name = 'ParentFolder'; Expression = {$_.Parent.Name}}|ConvertTo-Json' "]
    or
    system.run["powershell.exe -NoProfile -ExecutionPolicy bypass -c \"Get-ChildItem -Path c:\apps -Directory -filter tomcat-* | Get-ChildItem -Directory | select name, @{Name = 'ParentFolder'; Expression = {$_.Parent.Name}}|ConvertTo-Json\" "]
    • Hamardaban
      • May 2019
      • 2713
      try something like
      or
      • CristianR
        • Apr 2023
        • 12
        Hamardaban , thank you so much for your quick reply. I tested and the second one works perfectly.
        Cristian
