Zabbix Agent reporting high memory
  • Jonathan2260
    • May 2023
    • 12
    Hello. I am new to Zabbix and trying to set one up for my company.
    I have installed Zabbix 6.0.17 LTS and installed Zabbix Agent 6.0.17 on a few Windows computers. Zabbix is running in a VMware and on an AlmaLinux 9 distribution in case that matters.
    They are all reporting high memory in Zabbix but when I check the task manager in Windows, the percentage is much lower than what is reported.
    Looking further, the CPU is in the 40% on the PC but Zabbix is reporting it as if it's idle.
    I'm probably doing something wrong. Can anyone offer ideas on what to do?
    If you need more information, please let me know and I will provide it.
    Thank you.
  • Jonathan2260
    • May 2023
    • 12
    I ended up changing the agent and Zabbix server configuration and it's now reporting the memory correctly.
      Can you elaborate? Other people might benefit from this info...
      • Jonathan2260
        • May 2023
        • 12
        Sorry for the long wait. I had issues with the login. I can't recall now what was the exact problem. In the future, I will try to respond while my memory is fresh if I resolve my problems.
        • vijaymydam
          vijaymydam commented
          What procedure you followed to install the Zabbix Agent2 on multiple Windows servers? is it through Group policy ? or any automation tool like Ansible , BladeLogic?
