Trim not working for me
  • highway_fixer_man
    • Jun 2022
    • 35
    I have an item that returns file info. (vfs.file.get[/home/user/file.txt]
    I get back a string that looks like this:
    {"basename":"antipase_tag.txt","pathname":"/home/user/file.txt","dirname":"/home/user/","type":"file","user":"appuser","group":"appgroup ","permissions":"0664","uid":1000,"gid":300,"size" :86,"time":{"access":"2023-05-23T13:19:10.989292448+02:00","modify":"2023-05-23T13:19:10.989292448+02:00","change":"2023-05-23T13:19:10.989292448+02:00"},"timestamp":{"access ":1684840750,"modify":1684840750,"change":16848407 50}}
    I want to clean this up so that everything after "size" is removed. Basically, I need to know if this files permissions have changed - and I think this is the best way.
    I thought a "Right Trim" was the answer here - but its not working for me.
    If I use a "Left Trim" it also doesn't trim!
    I have tried every variation of the "size" marker as possible - "size" "size" *size* *size. etc - I really just cant get this to work. Seems like something simple.
    Any help appreciated.
  • Answer selected by highway_fixer_man at 23-05-2023, 15:09.
    Hamardaban
    • May 2019
    • 2714
    You misunderstood how this function works - it removes a previously known set of characters. Without substitutions.
    Example: input - "000123" \ the right trim function with param "123" will return "000".
    You need another function - Regular expression​!
    https://www.zabbix.com/documentation.../preprocessing
    for your case:
    pattern = ^(.*)size.*$
    output = \1
    • Hamardaban
      • May 2019
      • 2714
      for your case:
      output = \1
      • highway_fixer_man
        • Jun 2022
        • 35
        for your case:
        output = \1
        Thank you so much, Hamardaban - exactly what I needed. Very much appreciated.
