Zabbix Agent: monitoring multiple MySQL engines
  • giugiu
    • Sep 2018
    Hi everybody,
    I'm setting up Zabbix 6.0 LTS with several active agents on my infrastructure.
    Let me explain the problem I'm stuck with: I need the Zabbix Agent to monitor multiple MySQL engines residing on different containers on the same Docker server.
    How can I do that? At the moment I'm able to monitor only one MySQL instance with the "MySQL by Zabbix agent 2" template.
    ​I thought it would have been possible cloning the MySQL template (one for each DB-engine) and changing its name (along with items names) but Zabbix won't like items with same key.
    Thank you in advance
  • Answer selected by giugiu at 24-05-2023, 14:24.
    cyber
    • 4957
    Create a host per DB in Zabbix, you can use same template for each and use host level macros to define all the needed stuff (instead of template level).
      • 4957
      • giugiu
        • Sep 2018
        That worked.
        Thank you​
