snmp traps - Item key regex is failing to match
  • XynchroSTL
    • May 2023
    I'm using the following command to generate an snmp trap: snmptrap -v 1 -c public 127.0.0.1 '.1.3.6.1.6.3.1.1.5.4' '0.0.0.0' 6 33 '55' .1.3.6.1.6.3.1.1.5.4 s "eth0"
    I have an SNMP Trap Item created with the key: "snmptrap[]". Its type is 'Text' and it's a template Item. The template is associated with a host and when I generate the trap, the result shows up in the Host's data. So far, so good.
    Next, I create a dependent Item within the same Template, using the key : "snmptrap[IF-MIB::linkUp]". It's type is also 'Text' and it has the above Item set as its Master. There are no pre-processing rules involved. This dependent Item never generates any data. What might I be doing wrong?
    For reference, here is what the full trap looks like:
    20230524.160752 ZBXTRAP 172.16.238.1
    DISMAN-EVENT-MIB::sysUpTimeInstance = 55
    SNMPv2-MIB::snmpTrapOID.0 = IF-MIB::linkUp.0.33
    IF-MIB::linkUp = "eth0"
    SNMP-COMMUNITY-MIB::snmpTrapCommunity.0 = "public"
    SNMPv2-MIB::snmpTrapEnterprise.0 = IF-MIB::linkUp​
  • ISiroshtan
    • Nov 2019
    • 324
    Hey there,
    I'm not exactly see right away why dependent item fails in described scenario. But at the same time I fail to understand why would you go for dependent item in the first place.
    I would use available functionality of SNMP Trapper items. You an try do the following:
    Remove the 'snmptrap[]' item and create the fallback snmp trapp item with key like 'snm​ptrap.fallback'. This one will be collecting all the traps for this hosts that were not handled by other items. ​
    Then create 2nd snmp trapper item with key "snmptrap[IF-MIB::linkUp]".
    Now traps containing 'IF-MIB::linkUp' should end up in 2nd item while all the rest of the traps would fall in fallback item.
    • XynchroSTL
      • May 2023
      Thanks for the suggestion. The configuration that you suggested is actually how I'd first set it up. While researching the issue, someone suggested that creating a master Item to catch all traps and then handling specific ones as dependent is a good way to preserve the original full trap if it's ever needed for reference. That seemed logical so I went with it. For what it's worth, I just tried putting things back the way that you suggested with no change in results.
      • XynchroSTL
        • May 2023
        I found that it was interpreting the whole trap is a single line. If I add .* before and after the expression, it catches it. I'm able to then clean it up in preprocessing.
