Hello to the Forum
I'm trying to figure out whether it is possible to run a discovery only on local hosts supporting Modbus.
In order to do this, I'm looking for a way to configure a parameterized discover agent key like this::
Ip Range: 192.168.2.0-254
Check type: Agent
Key: modbus.get[tcp://{IP}:502,1,3,23298,1,int32,be,0]
where {IP} is a (hopefully feasible) parameter that holds the current IP of the discovery sweep and 23298 a Modbus register address known to exist in the devices to be discovered.
Does a parameter like "{IP}" exist in this context?
If this is not the case, where should I look into the Zabbix source code for adding a custom discovery method?
Thanks for reading
Raf
Check type: Agent
Thanks for reading
Raf
