Way to show unreachable dependents?
  • whabeck
    • Jun 2016
    I am creating a pilot program with Zabbix 3.0 on Ubuntu 14.04. I am wondering if anyone knows of a way to have dependents show as unreachable. For example... if I have 20 devices monitored and 5 of those are dependents of one other device. When that one device is down (ping check) and triggers as unreachable it does not show the dependents as unreachable. I then have to remember or look up the info on all 19 devices to see which are downstream from this so that I know the scope of the outage.
    I would like the alerts suppressed on the dependents, which it does, but would like to see that they are unreachable (PROBLEM state) and not show as OK.
    Thank you for your input.
    Will
