I'm trying to create a graph that shows two values. Item B is the current value, and Item C is the value from 24 hours previous. I've tried several methods but this is my current item setup:
Item A (Aggregate Item): grpsum()
Item B (Calculated Item): last("Item A")
Item C (Calculated Item): last("Item B", 86400)
I expect that Item B would be the actual value of Item A (essentially a copy), and I expect that Item C would be the value of Item B from 1 day earlier.
What I'm getting is Item B is a copy of Item A, and Item C is a copy of Item B (either current value or previous value).
The reason I created Item B is that time period is not supported with last, so I canno't do grpsum("Group",last,86400). Nor can I do grpsum("Group",sum,86400) since that gives me the sum of all values for the last day.
Any suggestions?
Any suggestions?
