Dashboard PopUp modify
  • globe
    • Apr 2006
    • 40
    Hi Zabbixer,
    I'd like to get an idea how i can integrate a 3rdParty URL in the Dashboard in the popup menu.
    Background: we're integrating a config archive system with ViewVC and new ticket system and like to have a direct integration from the Dashboard.
    I've been able to add it in /js/menupopup.js but all URLs get extended with the "sid" so it's unsable for 3rd Party URLs.
    Does someone have an idea?
    thx globe
  • globe
    • Apr 2006
    • 40
    HI @all,
    found a solution which helped me, so here's how i did it.
    Use Scripts:
    I used w3m, the command line browser on the console to grab the link per device and display it in a pop-up window, that’s exactly how I wanted it to work.
    it's very good that the Global Macros can be used in the command to make it dynamic.
    e.g.: Administration -> Scripts -> Create Script:
    Script run from Zabbix Server
    command: w3m http://<URL to Display>/{HOST.NAME}.html
    hope this helps others, as well.
    cheers Globe
    P.S.: above was done in Zabbix 3.0 but should work with others, as well.
    • zhura
      • Jan 2021
      need help adjusting height of dashboard popup to display all values. i'm weak in php programming stuff...
      or maybe i need just find constant "20" and change it to "26" but where to dig?
      Click image for larger version  Name:	Clip2net_2021-08-11_09_52_44.jpg Views:	0 Size:	63.4 KB ID:	429708
      found "svg-graph-hintbox" in "/usr/share/zabbix/js/class.csvggraph.js" here was constant "hint_max_rows" which i've changed from 20 to 30 but nothing changed... restarted nginx and php-fpm on zabbix server and cleared cache on my firefox - still only 20 rows
      there is no /var/cache/nginx directory on my zabbix server...
      so. substitution of options.hintMaxRows doesn't work for unknown reason but when i changes data.hintMaxRows all looks wonderfull
      Click image for larger version  Name:	Clip2net_2021-08-12_11_27_33.jpg Views:	0 Size:	50.7 KB ID:	429706
      problem was not in the browser or zabbix cache as i thought at first
