Actions on remote linux
  • guille.rodriguez
    • Jun 2022
    • 120
    Hi all, I have a template for Linux that have same service (for example apache, mysql).
    Sometimes website fails down because MySQL stops by OOM Kill, I solved the problem with OOM and after a few weeks it's solved.
    But I want to execute actions like
    systemctl restart mariadb.service when Trigger MariaDB Service is Down appears on host that triggers the problem.
    My first approach is using an action using Zabbix Agent, but fails because
    1 - Zabbix user on machine dont have home & shell configured on /etc/passwd.
    2 - Zabbix user on machine dont have permissions of sudo
    I've tried to changing thoose things on machine and it works but I don't want to configure this on all machines (I can do it with puppet / ansible... but I prefer ask other way).
    Is it possible using script executed on server? I tried and it works but I need to create 1 script for every server... is it possible to use some macro like {HOST.CON} like and argument, to execute some like this
    ssh root@{HOST.CON} "systemctl restart mariadb.service"
    On Windows I dont have this problem because Windows Agent is installed and executed as full admin, so ...
  • guille.rodriguez
    • Jun 2022
    • 120
    Nobody know how to do that?
      {HOST.CONN} → Trigger-based notifications and commands
      So yes...
