Disabling a single item on a host temporarily
  • iyossi
    • May 2016
    • 15
    I see there is a way to disable a host, but is there a way to disable just one/selected items in a host ?
    Regards,,
    Yossi
  • zabx_ks
    • May 2016
    • 48
    Hi iyossi,
    Of course it is possible to disable item.
    Go to Configuration - hosts - items and just click on item status to change status of it.
    Or click on check box if you want to disable more than one + disable button.
    more info you can read in documentation:
    zabx_ks
