Hi Community,
we have tested serveral Agent Versions (RPM and self compiled) and we expect a massiv memory leak/usage after a few days (reproducable over several systems):
To measure we used pmap:
Before Agent Restart, Runtime 15 Days:
"RSS: resident set size in kilobytes"
--> Which is about 14,57 GB Memory Usage!
After Restart:
After 5min Runtime:
Reducing the Host Config to the Linux Host Template, the Memory Usage stay at about 30 MB.
* We have Tested the Same behavior on 6.4.1-3;
* Agent is in Active Mode
* Encrypted and Unencrypted Connections didnt make a difference
* PersistentBuffer Configuration, doesnt make any difference
--> Our conclusio sofar is, that is seams to be an issue during the log file monitoring handling; After just activating one logfile monitor, the agent memory rises, slow but constantly.
Do you have some ideas or suggestions what we can do or check?
Thy & br
Daniel
[root@ ~]# pmap -x `pgrep zabbix_agent2` Address Kbytes RSS Dirty Mode Mapping ... ---------------- ------- ------- ------- total kB 17450152 15279072 15265116
After Restart:
---------------- ------- ------- ------- total kB 1925996 26132 10292
---------------- ------- ------- ------- total kB 1925996 30444 14604
Thy & br
Daniel
