The template found here:
Will not import into version 7.0.0alpha1. It did import successfully into one of the 6.x versions, I can no longer recall which version I was running when I added this template.
The error is `Incorrect trigger expression. Host "Template_ZFS" does not exist or you have no access to this host.` ... which is weird because that string is only given as the name of the template at the very top, there is no mention of it in anything that talks about hosts.
