MSSQL template preprocessing errors.
  • banff_rocky
    • Jun 2023
    From my Zabbix Linux VM, I got the ODBC connection and the front end template working but the only data I am getting is job successful, version of sql server, last backup etc. For the rest of the items, I am getting these errors in the screen shot.
    Host Macros:
    {$MSSQL.DSN} = db01
    {$MSSQL.INSTANCE} = MSSQL$db1
    {$MSSQL.PASSWORD}
    {$MSSQL.USER}​
  • banff_rocky
    • Jun 2023
    Any tips here on the cause of the issue?
      As error says "no data matches the specified path"... Verify, what is coming out to (master) item and is there all the data, what you actually try to extract.
      • PeterZielony
        • Nov 2022
        • 146
        it could be permission issue for user used to query SQL
        Hiring in the UK? Drop a message
        • banff_rocky
          • Jun 2023
          Get Performance counter is the master and a lot of the other items are dependent on that. There is no data in coming in for Performance counter. It has the follow SQL query:
          SELECT object_name,counter_name,instance_name,cntr_value
          FROM sys.dm_os_performance_counters
          UNION
          SELECT '{$MSSQL.INSTANCE}' as object_name,'Version' as counter_name,@@version as instance_name,0 as cntr_value
          UNION
          SELECT '{$MSSQL.INSTANCE}' as object_name,'Uptime' as counter_name,'' as instance_name,DATEDIFF(second,sqlserver_start_time ,GETDATE()) as cntr_value
          FROM sys.dm_os_sys_info
          UNION
          SELECT '{$MSSQL.INSTANCE}:Databases' as object_name,'State' as counter_name,name as instance_name,state as cntr_value
          FROM sys.databases
          UNION
          SELECT a.object_name,'BufferCacheHitRatio' as counter_name,'' as instance_name,cast(a.cntr_value*100.0/b.cntr_value as dec(3,0)) as cntr_value
          FROM sys.dm_os_performance_counters a
          JOIN (SELECT cntr_value,OBJECT_NAME
          WHERE counter_name='Buffer cache hit ratio base' AND OBJECT_NAME='{$MSSQL.INSTANCE}:Buffer Manager') b
          ON a.OBJECT_NAME=b.OBJECT_NAME
          WHERE a.counter_name='Buffer cache hit ratio' AND a.OBJECT_NAME='{$MSSQL.INSTANCE}:Buffer Manager'
          UNION
          SELECT a.object_name,'WorktablesFromCacheRatio' as counter_name,'' as instance_name,cast(a.cntr_value*100.0/b.cntr_value as dec(3,0)) as cntr_value
          WHERE counter_name='Worktables From Cache Base' AND OBJECT_NAME='{$MSSQL.INSTANCE}:Access Methods') b
          WHERE a.counter_name='Worktables From Cache Ratio' AND a.OBJECT_NAME='{$MSSQL.INSTANCE}:Access Methods'
          UNION
          SELECT a.object_name,'CacheHitRatio' as counter_name,'_Total' as instance_name,cast(a.cntr_value*100.0/b.cntr_value as dec(3,0)) as cntr_value
          WHERE counter_name='Cache Hit Ratio base' AND OBJECT_NAME='{$MSSQL.INSTANCE}:Plan Cache' AND instance_name='_Total') b
          WHERE a.counter_name='Cache Hit Ratio' AND a.OBJECT_NAME='{$MSSQL.INSTANCE}:Plan Cache' AND instance_name='_Total'​
          Should I execute this query on the database as the zbx_monitor user? Replace the {$MSSQL.INSTANCE} with the real instance name?
          • PeterZielony
            • Nov 2022
            • 146
            UNION
            UNION
            UNION
            FROM sys.databases
            UNION
            UNION
            UNION
            ​instance should be set as macro, but i don't think you need to manipulate code. Does the user you using for query DB got permission to read master db? Also can you see metrics from performance counters in Windows for MSSQL?
            On zabbix proxy/server used to query did you set STARTODBCPOLLERS?
            Click image for larger version  Name:	image.png Views:	1 Size:	48.4 KB ID:	465816​
            • banff_rocky
              • Jun 2023
              I edited the zabbix_server.conf file and uncommented:
              StartODBCPollers
              Number of pre-forked ODBC poller instances.
              Mandatory: no
              Range: 0-1000
              Default:
              StartODBCPollers=1​
              Once I restarted the service, it failed with an error code. Commenting them back let the service start as normal.
              Yes, using performance monitor I can see memory usage for example. The zabbix user on MSSQL server has db_reader and public permissions.​
              • PeterZielony
                • Nov 2022
                • 146
                StartODBCPollers
                Mandatory: no
                Range: 0-1000
                Default:
                StartODBCPollers=1​
                Yes, using a performance monitor I can see memory usage for example. The zabbix user on MSSQL server has db_reader and public permissions.​
                That's the problem. You need them to query SQL
                Are you uncommenting the whole block?
                it should look like this (depends how many SQL connections you need - 5 is lowest I'd use to query metrics)
                #StartODBCPollers
                [HASHTAG="t1783"]number[/HASHTAG] of pre-forked ODBC poller instances.
                #Mandatory: no
                #Range: 0-1000
                #Default:
                StartODBCPollers=5
                If that's the case, are you getting list of databases when running manually "db.odbc.discovery" item from discovery?
                I'm guessing you did setup ODBC driver on server?
                • banff_rocky
                  • Jun 2023
                  #StartODBCPollers
                  #Mandatory: no
                  #Range: 0-1000
                  #Default:
                  StartODBCPollers=5
                  Ok, just uncommenting StartODBCPollers=5 and restarting the service didn't result in any issues. Yes, I have ODBC driver installed and I can connect to the database using isql command. Still getting the preprocessing errors.
                  • Piotrekzielony
                    • Oct 2021
                    • 17
                    Are you getting any results from any odbc SQL query item from frontend?
                    That would tell us if frontend can make queries to db.
                    It can be simple select statement
                    • banff_rocky
                      • Jun 2023
                      In the front end all I am gettting is last diff backup, last full backup, last log backup. I am also getting success, last runtime, next runtime on hundreds of jobs.
                      • Piotrekzielony
                        • Oct 2021
                        • 17
                        So if you getting something via sql then your user doesnt have some permission to run this query it seems.
                        try running sql where you asked if you can replace instance macro with real instance as zbx user and see if you getting values then.
                        try in zabbix frontend and also using mssql studio.
                        Without seeing logs, errors or actual results that this query retuns we are just guessing
