Zabbix trigger unfunctional after database crash
  • globlalways
    • Jun 2006
    • 9
    My Zabbix DB recently crashed. After repairing the tables zabbix runs fine - means all data are collected correctly as I can see from the lastest data.
    But the trigger status does not work. In the trigger status overview most of the triggers have the status unkown. The triggers are not updated at all, even if the host-status changes. They have the value 2 (error) in the db and the lastchange is from a time before the crash.
    What can be wrong with zabbix?
    Can I force zabbix to reset all triggers from an error and see what happens?
  • globlalways
    • Jun 2006
    • 9
    Fix this issue with a database backup.
