Calculated item to summarize data from discovery items
  • ecce
    • Jun 2023
    I have managed to create a discovery rule and item prospects that gets data via SNMP from Cisco switches. As an example I have allocated stackpower, four switches in a stack consumes about 243 watts each. The key for the item prospects is stackpower.allocated.[{#SNMPINDEX}].
    I want to sum() the values, in this case four of them, to a power consumption value for the whole switch stack. My plan was to use a calculated item for this. But the item keys has a macro in it, I'm not sure how to summarize the values in a dynamic range of items. How do I solve this?
    Running Zabbix 6.4 on Linux, no proxy, collecting data via SNMPv3.
    Thanks.
  • Answer selected by ecce at 08-06-2023, 20:13.
    cyber
    • 4970
    sum(last_foreach(/*/stackpower.allocated.[*]?[group="your hostgroup"]))
    based on examples 1 and 2 here https://www.zabbix.com/documentation...ated/aggregate
    TBH, never tried, but if they work separately, why shouldn't they work combined... :/
      • 4970
      • ecce
        • Jun 2023
        Worked perfectly! Thanks!
        • Raoul_8
          • Mar 2024
          Hello, I am having a problem with making a calculated item in a discovery rule.
          I have a discovery rule for the filesystems.
          Now I want to make a forecast item, which calculates how much space is used 30 minutes later.
          This is the formula I have been using:
          forecast(//vfs.fs.dependent[{#FSNAME},pused],30d,30m)
          I get the following error:
          Cannot evaluate function: item "/{HOST}/vfs.fs.dependent[{#FSNAME},pused]" does not exist at "forecast(//vfs.fs.dependent[{#FSNAME},pused],30d,30m)".
          I am currently using Zabbix version 6.4.12
          Thanks in advance!!
          • Hamardaban
            • May 2019
            • 2714
            How exactly is the item key written?
            /{HOST}/vfs.fs.dependent[{#FSNAME},pused] or //vfs.fs.dependent[{#FSNAME},pused]​ ?
            In “forecast​”, you need to use exactly the same as the key.
            • Raoul_8
              Raoul_8 commented
              Thanks for the help.
              I already figured it out. It did not work in the test since I used {#FSNAME} but when I use C: or another drive it works.
              Sorry for my stupidity on this matter.
            • Hamardaban
              Hamardaban commented
              You're welcome
