Two LLD with same key on one node
  • sperr0w
    • Oct 2014
    • 44
    Hello!
    may be somebody already solve this issue.
    I need to attach different triggers and metric interval for different filesystems that discovers in LLD rule.
    for example 60sec and Critical threshold for / and 600 sec and Warning threshold for /var.
    In this case I actially need two discovery rule, that will discover me different filesystem.
    I can set up rule to discover different filesystems by using filters, but I cant create two rule with the same key vfs.fs.discovery.
    also it is not possible to use vfs.fs.discovery with [], that could solve problem. For example vfs.fs.discovery[customer_fs], vfs.fs.discovery[admin_fs].
    The only solution I can find right now - is to create custom LLD key for filesystems, but it is not cool.
    May be somebody know other solution?
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Dirty workaround is to create Alias in agent's configuration file for vfs.fs.discovery (as many as you like) and use them as keys.
    • pfouquet
      • Jan 2012
      • 10
      It should be possible in 3.2 (sponsored dev by my company)
