Facing issue while Scheduling the item task
  • ArunAA
    • Jun 2023
    Hello all,
    I want to schedule my item task to run once in the day every night at 11:30 pm and the output should also print once after the item task. I followed some articles and set the value as:
    Update interval - 60s
    custom interval type - scheduling
    interval - wd1-7h23m30
    I set the value as mentioned above but it didn't work at all, it is running after every 5 minutes no matter what I do. I request you all to please help me to resolve the issues.
    What type of item you have there? Have read (and understood), what is said here https://www.zabbix.com/documentation...ling-intervals ?
    You do have a fundamental error already in your values...
    update interval -> 0 !!! Because scheduled interval is ADDITIONAL to this...
    interval -> h23m30 (no need for wd, if you run it every day)
    If we talk about active items here, then those will work only with agent2 like this... classic agent has no timer, so any custom interval has to be with passive item.
    • ArunAA
      • Jun 2023
      Hello thanks for your reply,
      I am running a malware scan on my servers through Zabbix items.
      I tried your interval modified setting but it is still not working correctly. I set it as h20m30 for testing purposes. I got the result at 21:39:14.
      Please help me with this issue.​
      • ArunAA
        • Jun 2023
        Hello sir, I
        am still facing the same issue. I set the value to run the item at 1:15 pm every day but it shows the result at 7:45 pm and also it executes the item after every 5 minutes which is very scary for my servers.
        Please let me know a solution regarding this ASAP.
