How to detect if X latest items are increasing on Zabbix 5?
  • lbon
    • Dec 2022
    • 14
    I have created an item that pulls number of messages from a queue. I want to monitor if this queue is not decreasing. I cannot find the correct trigger for this. Anyone?
  • lbon
    • Dec 2022
    • 14
    No solutions?
    • PeterZielony
      • Nov 2022
      • 146
      you can have a go with
      monoinc(/host/key,(sec|#num)<:time shift>,<mode>)
      https://www.zabbix.com/documentation...istory#monoinc
      I've got few things I wanted to set this up with but had no chance yet to configure this function but it should suit your needs.
      You can set [HASHTAG="t19"]num[/HASHTAG] to 2 to compare the current with the previous value received and detect an increase in your trigger
      Hiring in the UK? Drop a message
      • lbon
        • Dec 2022
        • 14
        Thanks... but seems only to work in Zabbix 6.
        No solutions in 5?
        • PeterZielony
          • Nov 2022
          • 146
          Oh sorry, didn't know it was introduced in 6
          try it maybe like this :
          max(#3)-min(#3)>0
          this will detect if max and min differences are bigger than 0 between last 3 values (it picks the biggest and smaller value). This will get your trigger up. It might not be correct syntax but you can work out this logic ​
          • Semiadmin
            • Oct 2014
            • 1626
            You may create for an item (for example, queue) a dependent one (for example, queue_delta) with simple change in preprocessing and compare number of values per period.
            The idea is that the values of the dependent item with a negative change will be discarded.
            There is a small problem that the trigger condition will be calculated when the master-item receives a new value, and the dependent one does not yet.
            Therefore, it is necessary to add a small delay to the trigger. I assume that the update interval is at least a minute.
            Problem: queue.count(1h)<>queue_delta.count(1h) and queue.nodata(30)
            Recovery: queue.count(1h)=queue_delta.count(1h)
            If you need to monitor a continued growth (like monoinc() in strict mode), use queue_delta.count(1h,0,ne)​
