failed to send email after upgrade from Zabbix 5.0 to 6.0 LTS
  • Cloud8x4
    • Dec 2013
    • 24
    Until last week, I used Zabbix 5.0 LTS on a zabbix web and a zabbix server docker via docker-compose.
    I had several actions working, using the following configuration mail configuration.
    Click image for larger version  Name:	image.png Views:	0 Size:	51.0 KB ID:	465837​
    After the upgrade, using docker-compose, e-mails are not sent.
    The docker log shows `failed to send email: Timeout was reached: Connection timed out after 40001 milliseconds`.
    I tried changing the port from 587 to 465 and 25.
    I tried setting the username and password again.
    Running `telnet email-smtp.eu-west-1.amazonaws.com 587` results in `220 email-smtp.amazonaws.com ESMTP SimpleEmailService-d-23UDTQ3MO 5GJgwrIGumdOLTspYliE`. I don't expect that suddenly something changed in the network so the SMTP service should be available.
    I tried turning off authentication.
    I tried creating a new media type using the same settings.
    Please help.
    Thanks in advance.
  • Cloud8x4
    • Dec 2013
    • 24
    Yesterday I followed the instructions in the Zabbix 6.0 upgrade manual to add primary keys.
    Sources
    https://git.zabbix.com/projects/ZBX/...35c88a02dc8365 .
    So I stopped the zabbix dockers and ran the procedure.
    After starting the docker for the zabbix-server again, the logs then showed `failed to send email: Login denied` instead of the timeout message earlier.
    Renewing the credentials in Amazon and the updating the media type credentials via zabbix web hen solved the issue.
    E-mails are sent again.
    So it is unclear what was the cause of the issue and what exactly the solution, but I'm happy it works again.
